my 60in twin fpv wing New flight footage.
by mhartman550 | August 21, 2013 | (6) Posted in Projects
 Well she made it in the air! flys beautifully exept for a bearing going out on a motor...did have a fun time trying to keep it from catching fire
Howdy,
Well this was inspired by the ft Versa. It is built in a very
similer way. it is made of 4 sheets of foam board and has
a 60in wing span. hope you enjoy!
 i started by giving it a 20 degree angle for the leading edge
same building style as the versa
the versa wing on top of it
it is powered with two 1000kv motors useing the ft
elements motor mounts.
 it has counter rotating 10 4.7 props
 it can have 9 7 props or 10 4.7
 it has two 30amp esc's and each motors runs off a three cell lipo 1800 mah
 neering completetion
thanks for looking!
lazyb4 on August 24, 2013
I am still going to build standard FT Versa but this 60" of yours looks great. I would like to build one of that size too. I'll bet that it will carry some serious FPV gear! Good job!
mhartman550 on August 24, 2013
thanks, although I did go a little over board with my two motors. it could hover at just a little over 1/4 throttle
Corsair2014 on August 24, 2013
Nice! reminds me of my Bird of Prey wing
mhartman550 on August 28, 2013
Well I've been having issues with the twin setup. one motor keeps burning up. im not over propping the motor or anything. I cant figure out whats wrong. the wing its self flys great. but im designing a new wing for just a single motor. its gonna be about a 55in wing
28th St. Air on August 24, 2013
Looking forward to seeing your build dimensions.
I'm back at home this weekend. but once I get back to my dorm I have plans drawn up and ill post them
Flying Penguin RC on August 22, 2013
can't wait to see the maiden flight, should be a good one.
mhartman550 on August 22, 2013
I hope so! Im having issues getting the cg right. with two 1800 3 cells and a 3000 3 cell its still tail heavy
JustinTime on August 22, 2013
Put the motors on the front. lol
Jord907 on August 22, 2013
You could make it have a tractor motor on the front and a pusher on the back.
would help with the CG issue. might look a little funny though =)
ghostrider03z on August 23, 2013
dude with two motors you could carry two 5000 mah batteries...
I just have to buy them! I was just trying to get away with out buying anything else.
sailorJohn on November 7, 2013
Rather see the plane flying.
