Somewhere during the upload youtube decided to completely destroy the video quality, so it is kind of low but not terrible. This wing size is honestly just the "Magical" size for an easy going flying wing. I really reccommend you build it if you live in a windy area. Where I live it is constantly over 10mph winds and this plane doesnt even care. All the specs are at the end of the video but here are some links to the parts. CG is ~6.5 inches from the nose when plane is upside down.
Motor - http://hobbyking.com/hobbyking/store/__2069__hexTronik_24gram_Brushless_Outrunner_1300kv.html
Prop - http://hobbyking.com/hobbyking/store/__9842__SF_E_Prop_8x3_8_203x96_5mm_w_Adapters_Black_5pcs_bag_.html
Servos - http://hobbyking.com/hobbyking/store/__16260__HKSCM9_6_Singlechip_Digital_Micro_Servo_6V_10g_1_6kg_0_07s.html
ESC - http://hobbyking.com/hobbyking/store/__4312__TURNIGY_Plush_18amp_Speed_Controller.html
Battery - Any 2200mah 3s
I also have put my gopro on the plane with an 800mah 3s battery and it works fine. Hope you enjoy!
Is it a delta or a flying wing? Does it roll or pitch to go inverted?
If it's a flying wing (zephyr-like): check your cg http://fwcg.3dzone.dk/ an put your elevons about 8 degrees up so you get a "s shaped airfoil" commonly used on flying wings for stability.
If its a delta: you could also use a symmetrical airfoil (like the ft delta) and also check the cg!
Good luck
...make a kfm-4 airfoil out of it. not much effort, it's symmetrical and should also work.
