Low Cost Telemetry and Data Logger Turnigy GTY-i6
by yves.morele | October 24, 2020 | (0) Posted in How To
 1 INTRO:
In a previous article, I describe a low cost GPS data logger for rc aircraft, but without telemetry.
The telemetry is very important in aeromodelling for controlling battery level, altitude and more.
This project describes a very low cost data logger for rc aircraft with real telemetry on the transmitter for put in in a radio controlled plane.
More, the power for arduino be made by the receiver of the plane to have less weight on the plane and with a small size.
2 CHOICE OF MATERIAL :
For the microcontroller : Arduino nano generic
For the GPS : UBLOX NEO-6M V2
For the sd card reader/writer : generic but the less weight as posssible
For the box : ABS box
I made this choice so as to have the smallest components possible (I did not choose the arduino micro for lack of memory) and with the least weight.
3 ASSEMBLING :
The wiring must be done with the minimum length of wire and without the connectors on the electronic cards so as to lighten the final assembly to the maximum.
4 DISPLAYING:
The data is displayed on the transmitter by selecting the sensors and setting the alarm
5 Schematics:
6 Code :
#include <iBUSTelemetry.h> //https://github.com/adis1313/iBUSTelemetry-Arduino
#include <Wire.h>
#include <TinyGPS++.h>
#include <SPI.h>
#include <SD.h>
//pin pour carte SD
const int cs_sd=2;
TinyGPSPlus gps;
#define UPDATE_INTERVAL 500
// pin voltage
#define dP A0
iBUSTelemetry telemetry(9); // arduino pin pour donnes iBUS
  uint32_t prevMillis =0// neessaire pour updateValues()
  //LED
     const int verte = 3;
     const int rouge = 4
     float maxspeed = 0speed1 = 0;
     int maxhigh = 0high1 = 0;
     int maxsatelite = 0satelite1 = 0;
  float meters ;
  float voltage=0.0;
void setup()
  Serial.begin(9600);
  pinMode(rougeOUTPUT);
  pinMode(verteOUTPUT);
  //Condition vrifiant si la carte SD est prsente dans l'appareil
if(!SD.begin(cs_sd))
  digitalWrite(rougeHIGH);//absence SD
     return;
 digitalWrite(rougeLOW);// carte SD absente
     File data = SD.open("donnees.txt",FILE_WRITE);              // Ouvre le fichier "donnees.txt"
     data.println(""); data.println("Demarrage acquisition ibus"); // Ecrit dans ce fichier
     data.println(""); data.println("date      heure       latitude       longitude   altitude    vitesse");
     data.close();
  Wire.begin();
  telemetry.begin();
 // definition capteurs
  telemetry.addSensor(IBUS_MEAS_TYPE_ALT); //altitude
  telemetry.addSensor(IBUS_MEAS_TYPE_EXTV); //batterie
  telemetry.addSensor(IBUS_MEAS_TYPE_SPE); //vitesse km/h
  telemetry.addSensor(IBUS_MEAS_TYPE_GPS_LAT); // latitude
  telemetry.addSensor(IBUS_MEAS_TYPE_GPS_LON); // longitde
void loop()
     updateValues();
     telemetry.run();
void updateValues()
// lecture donnes Gps et allumage LED si OK
    if (Serial.available()) {
      digitalWrite(verteHIGH);//donnes Gps OK
      gps.encode(Serial.read());
  float meters = (gps.altitude.meters());
  voltage=float(analogRead(dP))*(20/1023.00);
  float airSpeed = (gps.speed.kmph());
// definition vitesse max
     speed1 = (gps.speed.kmph());
     if ( speed1 > maxspeed) {
      maxspeed = speed1;
  // recuperation date et heure du GPS pour datalogging
       String Temps=String(gps.time.hour()+1)+(":")+(gps.time.minute())+(":")+(gps.time.second());
       String Date=String(gps.date.day())+("/")+(gps.date.month())+("/")+(gps.date.year());
// Temporisation
    uint32_t currMillis = millis();
     if (currMillis - prevMillis >= UPDATE_INTERVAL) { // Code in the middle of these brackets will be performed every 500ms.
         prevMillis = currMillis;
// affichage donnes capteur sur radiocommande
  telemetry.setSensorValue(1, (meters )*100.0  ); //  altitude
 telemetry.setSensorValue(2voltage*100  );
 telemetry.setSensorValue(3speed1 );
 telemetry.setSensorValue(4, (gps.location.lat()*10000000));
 telemetry.setSensorValue(5, (gps.location.lng()*10000000)) ;
    // Ecriture des donnes dans le fichier texte
     File data=SD.open("donnees.txt",FILE_WRITE);
     data.println(Date + " " + Temps + " " + String(gps.location.lat(), 6)+" "+String(gps.location.lng(), 6)+(" ")+String(gps.altitude.meters(),0)+(" ")+String(speed1)+(" ")+String(maxspeed));
     data.close();
Download the ibus library here
7 RESULT :
In the next video you can see the result.
The data can be import in google earth for visualisation of the trajectory of the plane.
PCBpartner on July 26, 2022
Glad to see such an in-depth article, thank you very much.
As a pcb supplier, I am very sensitive when you PCBs. pcbpartner is an affordable PCB manufacturer in China. You can quote PCB prototypes online. Come to realize your PCB prototypes now.(https://www.pcbpartner.com/)
