Kyosho Micro Planes
by RCmaniac | February 17, 2013 | (3) Posted in Reviews
The Kyosho Minium AD Profile Extra 330SC is an okay airplane. I bought one a few weeks ago from amain hobbies. I got it flying. The sad thing about it is that to me it has more down sides than up sides. I'll start with the up sides.
- Good at 3D aerobatics
- Light weight
- Simple to build
- Comes with everything you need but the foam safe CA glue
Down Sides
- Very fragile.
- Hard to work with because of the micro components.
- Difficult to find replacement micro components, not only that they are very expensive.
-  It does not do well in the wind.
- Very unstable.
- The 3mm depron it comes with will break very fast.
- Very weak and easy breaking servos.
In conclusion I do not recomend this airplane to a begginer or anyone who has never done a scratch build. Start with the Flight Test swappables, or if you have never flown a rc plane before start with a rtf trainer and if you get into scratch building, I think the nutball is for you!
Thank you for reading my reveiw and I hope it helped you on anything!
Adib Vahedi on February 20, 2013
Thanks for the heads up!
Keep up the great work!!!!!!!!!!!!!!!!!! ;)
RCmaniac on February 20, 2013
Thanks!!! :)
Kyosho Micro Planes
