Flashing KK2.1 Firmware in Mac OSX and Windows
This is a part of a much more involved tricopter build video series. When the build is complete, I'll turn that series into an article. However, there seems to be a lot of folks needing this specific information, so I am breaking it out into it's own separate article.
In this video, I go through the process of updating my KK2.1 FC Board to the latest firmware (released by Steveis). I performed my update using a Mac, but I realize many folks are using Windows and could use some help as well. There are already a lot of great videos on how to do this, but I don't know any that are as comprehensive as this...so hopefully it's helpful for folks.
The first 8 minutes of the video is the overall how-to and actually performing the update on my MacBook Pro. I go over the Windows portion starting at 08:17 (including installing the USBasp drivers).
Video:
Screen Shots from Video:
Anyway...you can't go wrong with the 9xrprogrammer.com programmer! If you have any questions that I didn't cover in the video...just let me know.
Here are a few videos I did on the 9XR. It's a four part series on starting from scratch with the 9XR and flashing OpenTX and some basic programming and setup.
http://www.youtube.com/watch?v=u62GV22-bUc
http://www.youtube.com/watch?v=hRNkx-GrLOc
http://www.youtube.com/watch?v=qqs8Py60hzo
http://www.youtube.com/watch?v=-rgdIzZixiQ
Thanks for doing this :)
I recently assembled a Flamewheel 450 and it flies well with one major exception. I cannot land the quad without breaking an arm or a prop. When I lower the throttle to descend it’s as if the 4th motor shuts off completely instead of in synch with the other three, thus causing a crash, EVERYTIME! I’ve calibrated the ESC’s. The props are balanced. The CW and CCW motors/props are operating in the correct orientation. All channels are operating properly. Has anyone else experienced this? If so, how did you fix it or can you point me in the right direction? I’ve read on various newsgroups that it could be my settings but all the information varies. I’ve also read that it could be a “lazy 4th motor”. I tried flashing the KK board with 4.7X but it didn’t work. I believe that firmware was for the KK 2.0 only. I’ve been flying multi-rotors LOS and FPV for over a year however I’ve only used the NAZA FC. This 450 houses a KK 2.1. The specs on my quad are below. Any assistance will be greatly appreciated as I’m starting to run out of spare parts. Thanks in advance.
Platform: DJI 450
FC: KK 2.1
Firmware: Stevies 1.2S Beginner (All default settings)
Motors: DJI 30A
ESC: Turnigy Plush 30A
Props: Stock DJI 10x4.5
