An Ion-Powered Plane Has Flown for the First Time
by FliteTest | November 22, 2018 | (7) Posted in News
What's the future of aircraft propulsion? Well, this team from MIT might have just shown that it's 'ionic wind'.
Ion-power as a means of propelling aircraft, although already used for spacecraft, has never before been successfully demonstrated - that is until now. Recently, a team from MIT successfully flew an ionic model aircraft with zero moving parts.
Note! If you're simply looking for the video of the flight, scroll to the bottom of this article. You're welcome!
The Experiment
Researchers have been investigating the feasibility of building an ion-powered aircraft. They believe this propulsion method could be used for ultra-quiet drones and even hybrid airliners.
They've been carrying out a series of practical experiments with an unmanned RC airplane. They don't have a specialist laboratory or testing grounds, instead, they've been hiring an ordinary gymnasium.
The tests have confirmed that a plane can propel itself with ion-power alone. The airplane only found it's limit when it crashed into the far wall of the gym.
How it works is relatively simple to understand: high powered electrodes are used to ionize the air. The huge voltage across the surface of the electrodes (40,000V)  strip negatively-charged electrons from air molecules which are attracted to electrodes at the back of the aircraft. In turn, this sweeps other air molecules along with them producing an 'ionic wind'.
So what is the feasibility of powering airplanes with ion drives in the real world? Clearly, the 197-feet flight of the prototype gymnasium airplane proves there is a great deal of potential in the technology. Yet, it must be remembered that the aircraft in these tests needed a large electrode surface area to produce sufficient thrust for flight. Air density might also be a restrictor to where ion drives like the one tested will work: higher altitudes may hold too few air particles to ionize. Smaller unmanned aircraft flying at low altitudes, therefore, may be the first types to be ion powered.
Video
If you want to see this plane flying for yourself, check out this interview and flight footage. The successful ion-powered flight is quite surreal looking.
Links To More:
Information on 'Ionocraft'
The History of Hover Platform Technology
The Flying Submarine
Here's Why Supersonic Airliners No Longer Exist
Images courtesy of MIT
Article by James Whomsley
Editor of FliteTest.com
Contact: james@flitetest.com
YouTube Channel: www.youtube.com/projectairaviation
EthanKrauss on December 19, 2018
The first Ion propelled aircraft to carry its power supply, is covered under US Patent # 10,119,527. It is NOT MIT. Google it!
Dave B on November 25, 2018
Wow.
ccdman on November 24, 2018
Just checked the MIT web site http://news.mit.edu/2018/first-ionic-wind-plane-no-moving-parts-1121, and there is a wee bit more info: "weighs about 5 pounds and has a 5-meter wingspan". No wattage data.
Thorondor95 on November 22, 2018
So TIE fighters CAN become a reality...
Eggs Benedict on November 22, 2018
I think this is really cool! I had been curious about the idea myself, so it is interesting to see someone exploring that. The engine may not be very powerful yet, but now that it has been made, the technology can be refined so it is usable in some way.
EthanKrauss on December 8, 2018
MIT was not first to fly an ion propelled device with an onboard power supply!... Here is the website showing videos of the first one. It can go straight up for around 2 minutes: elecronairllc.org
Reply
Delete Comment
I wish there were more information available - like the power and thrust levels - how many watts of input power, weight and lifting area of the plane, etc., And I wonder what would happen if you flew through a cloud, or even highly humid air - arcs and sparks?
