Introducing the Desert Dog, a DIY foamie plane
by NYCBobby | November 3, 2020 | (2) Posted in Projects
Want to turn 4 sheets of foamboard into a plane that can fly off water, wet grass, or even snow? Build a Desert Dog, the FT foamboard version of Hobbyking's Arctic Cat.  Check out the assembly pdf document and all the drawings are here for the downloading.
Desert_Dog_Article.pdf
DD1.dwg
DD2.dwg
DD3.dwg
DD4.dwg
DD5.dwg
DD6.dwg
MMGRAY.dwg
DD1.DXF
DD2.DXF
DD3.DXF
DD4.DXF
DD5.DXF
MMGRAY.DXF
AERODROME on November 8, 2020
KEEP DAYLIGHT
Geezer Fly on November 20, 2020
Nice plane but the posted drawings are not going to be accessible to the vast majority of us in the FT community that do not have CAD software. Would you please save them as PDF and re-post? Thanks
Oldraceman on November 24, 2020
I'm with Geezer Fly this is a nice plane and I would like to build it as I have several wings flying. But like most I do not have a good cad program. It can be imported to 123d design but it will not export the file to one that can be used. Like most of us the have a cutter or built one may use inkscape to set up the cuts. Please redo the files to pdf for this program to use.
