i have just added a battery hatch to my ft pod for the bloody wonder
1 cut out a hatch just bigger than the batt that your using
2 hot glue a piece of plywood at the front of the hole you just cut in the pod
3 extreame tape the hatch all over as it will be used a lot
4 get old spare servo horn and a longish screw and washer and nut mark where the servo horn will lock the hatch and the cut the foambord to take the horn.(just at the front of the hatch opening)
5 screw the servo horn through the foam board and through the plywood an attach the nut
6 put a piece of tape as a hinge to join hatch to the pod
7 add a small piece of tape to the hatch so that you can open the hatch as it a tight fit
job done
add velcro if you wish to hold the battery
