How to setup DLG glider with Spektrum Radio
by gcok2010 | July 5, 2017 | (0) Posted in How To
It is really easy to setup simple DLG glider with Spektrum DX9 radio.
In this video everything is explained from start to the end on how to setup 2 channel DLG with elevator and rudder controls. Starting from creating new model and selecting aircraft type, selecting wing type, binding and finally creating two flight modes.
Many people avoid making Launch and Cruise Flight Modes, but I think that it is necessary. There are different forces that act on the glider during launch procedure than when glider is in cruise mode searching for thermals. The other thing people forget is make trims independent in these two flight modes, or just don't know how to do that.
I must point out that all trims in this video is just for showing you people how it works and how to make adjustments. You will need to test your model and trim as neccesary in both Flight Modes.
I hope that this video will help people setting up their DLG gliders properly.
gcok2010 on July 10, 2017
If you need more Spektrum setup explanations, comment here what would you like me to explain.
