We are so thankful for your support and excitement about our newest design: the FT Gremlin! Without your passion for the RC hobby, we wouldn't be able to make these designs possible! Last week, we listed it online and your response was incredible! In this build video, TJ takes you step-by-step to create your own FT Gremlin!
http://rotorgeeks.com/index.php?route=product/product&product_id=54
http://forum.flitetest.com/showthread.php?17136-SP0NZ-Plans-Index
This was not clear, and it took me a while to find the app. Betaflight was already flashed on my F3 Femto when I received it with the Gremlin.
I made the model work with both the EMAX power pack micro system motors or the a standard 9mm 1104 motor mount
http://www.thingiverse.com/thing:2300936
1st, let me say thank you for your desire to make this hobby as accessible as possible.
2nd, I'm confident this will get worked out though a bit frustrated I haven't figured out the problem.
3rd, the problem is I can't get the board to be recognized on my Mac. My tricopter is recognized no problem in both CF and BF but the F3 Femto neither. Tried various cables and ports, no joy. Any guidance would be appreciated.
Lastly, you guys rock. I thoroughly enjoy how you all support the idea of family. God bless you all.
—Jim
Suggestion: Mark your USB cables to distinguish the ones that accompany devices for charging purposes or at least mark one as a good one for actual data use.
Even after getting it to connect to beep when plugging it into the computer, I still had problems getting the drivers set up. I finally found this youtube video that explains everything very clearly. After following along and getting the drivers set up everything worked. Hope this link will help others having problems.
https://youtu.be/m4ygG6Y5zXI
Note to FT Guys, a heads up on this in the FC envelope would be a nice touch!
I did run into problems at the end when I could not get the blheli suite to recognise the quad at all , no connection at all.. however there is a newer blheli configurator app that runs through chrome.. This app worked perfectly , connecting straight away, and using the app, I was able to flash the latest bl firmware and set the correct motor directions very easily, the chrome app is much easier than the blheli suite method..
The blheli configurator app and the betaflight can be run at the same time, and by disconnecting from one you can then connect to the other, swapping back and forward is easy.. which saves time..
I did not need to flash the firmware myself, but at 5:54 TJ claims the programming was successful, but the video clearly says, “No response from the bootloader, programming FAILED”. This is the sort of thing that will drive a new user insane….
Here is a list of some of the critical information that I consider to be missing:
1. What kind of USB cable do you need?
2. Where do you get Betaflight, including the user documentation?
3. How do you install it on your computer?
4. Where do you get the special driver that it needs and how do you install it?
5. Where do you get the BLHeli Suite, including the user documentation?
6. How do you install it on your computer?
At the very least, links need to be provided to the locations where this information can be found. Poking around on the internet among all the mis-information and malware is not a good option.
The Transmitter setup is poorly described. There is no mention of using trims or sub trims to center the controls and prevent gyro drift. There is no mention of the endpoint or travel settings required. This is especially important for throttle as the stock 100% throttle travel is insufficient to allow the flight controller to arm. It requires 120% minimum.
There is no mention of AutoLevel calibration in Betaflight. Mine was way off. Between this and the improper trim settings the Gremlin would be unflyable for a beginner.
You really need to slow down when working on the computer. Even with pause and rewind it is difficult to see what you are doing.
