Homebrew wind tunnel
by nickatredbox | October 25, 2013 | (0) Posted in How To
 This is a wind tunnel I used to work in as a software engineer
Battershell on October 25, 2013
Very informative. Loved the dry ice smoke visualization over the wing types. I clearly understand the different geometry of the wings you tested now. All you need for your wind tunnel is a wall of straws to disrupt the turbulence from your fan.
nickatredbox on October 25, 2013
I liked the open jet tunnel at the top only thing is to maintain accurate scale speed and therefore measure loads you need to know barometric pressure,delta pressure across the contraction and temperature at the minimum to correct the measured values
