I bought Integrated PCB MICRO QUAD from hobbyking.com after watching the video from flitetest and I really love how it flies. The only problem is that those arms are so easy to break and after over fine times of breaking arms, I decide to just get my own wood frame that can be easier to fix (I hope) and here they are.
And here is some close up pictures.
I should clean up cables :) And also noodle is my favorite landing legs for sure..
Here is from up close it. I put the light from hobbyking for orientation and look.. It uses the 12cm each lenght arms with 3cm x 3 cm wood brick as mail frame. I used drill to make it first first and used wood glue.
More closer shot
Front shot. I used the crews from servo left over to screw the motor mount and use ziptie to finish up.
Upside down pictures
Close up picture from up side down.. as you can see i still keep the arms as it is useful when you change the motor and no need shink tube..
Power distribution with cables
Thanks!!
