Hobby king Tek Sumo wing review and maiden
by kirikset | April 28, 2013 | (4) Posted in Reviews
I received this Teksumo flying wing over a month ago but never had time to fly it. Finally this weekend was quite free and spring finally caught on.
Summary of my opinion on this plane:
  1. Easy to launch
  2. Unlimited vertical with my setup and any reasonable one
  3. Great gliding performance
  4. Very tough
Negative points and things to note:
  1. Needs 40-50% expo on max travel in case you dont use full throw like me
  2. Mix 66% of elevator and 100% of ailerons, very sensitive to pitch input
  3. A lot of uptrim from what I considered neutral before flying - almost 20% up trim on reciever because otherwise it pitches down. Tune it so that in neutral the top of the aeileron is horizintal, not the bottom
I review this plane, its flight characteristics, positive and negative points.
Videos of my first flights are included.
Teksumo is very fast, light and tough. Not a first plane or a beginner one in my setup. Very easy to build one that has unlimited vertical, good glide ratio and reasonable flight time.
My setup is geared toward more speed but is not very pricey ($118 total + shipping).
Using a cheaper prop, motor and reciever this plane can be built for less than $90.
- Teksumo kit $30 from Hobbyking http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=17969
- Corona servo 939MG 2pcs $6 each from Hobbyking http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=10346
- FrSky D8R-II PLUS reciever $23 from Hobbyking (use a receiver that you use, I just prefer FrSky) http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=14356
- Turnigy nano-tech 1300mAh 3S 45~90C Lipo Pack $12 from Hobbyking (best 3s of this size I've ever used) http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=18207
- Motor GH Micro Jet V3 2200kv 2826 size $24 http://www.graysonhobby.com/catalog/ghmicrojetv3brushlessoutrunnermotor-p-425.html
you can use this outrunner from Hobbyking http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=12919
I use noname ESC (use any 30a ESC like TURNIGY Plush 30amp) and APC-E 6x4 prop (about $5) that is not sold on hobbyking
jerimiah85 on April 29, 2013
I went to order this wing and there out of stock :( I also have all 3 super jet motors and my fav by far is the V2 supersonic not as much roll on full stick . nice video
kirikset on April 30, 2013
It is very frustrating that hobbyking runs out of stock so often(
BTW I think Teksumo is a clone of this plane: Popwing 900mm. It can be available somewhere.
for example for $33 at Nitroplanes http://www.nitroplanes.com/02a-019-popwing-epp-green-kit.html as of 2013 04 30
