High Wing Trainer
by ghostrider03z | October 16, 2013 | (5) Posted in Projects
 First off, should I do a build video? I got some basic pdf's made and the wing is easy to do, i just need some interest before i would make the build video.
So i always like my share of slow flying type planes and made this. Its a real basic design, i mean if you cant beat it, join it.
It is a 41 inch wing with an 8.5 inch cord.
Motor (from this kit): http://www.rctimer.com/product_786.html
Esc: 30 amp
Battery: 2200 3s
Prop: 9x4.7
It is full 4 channel control.
Let me know if you want a build video for this.
PDF Download: https://www.mediafire.com/myfiles.php#86mezy72q1z2k
I do not have the wing/ailerons in the PDF since they alone take 11 pages and is a huge waste since there is nothing hard about cutting out the wing by hand.
Dimensions of wing: 8.5 x 41
Ailerons: 2 x 18
The wing is a ribbed wing (so you need two 8.5 x 41 6mm pieces of foam). The thickest part of the curve in the wing is 3/4 inch and is about 3 inches back from the leading edge. Here is how I make this style of wing: http://www.youtube.com/watch?v=EEgVogpcJuY Also the two little lines in the fuselage in the PDF is where the wing should go. Thanks for watching.
rcfreaky101 on October 17, 2013
hey i was just wondering where did u get that foam and do you know what the foam is called or the brand of the foam. thanks. great plane by the way and flies great. keep up the good work
ghostrider03z on October 17, 2013
the fuseloge is 2 inch thick pink insulation foam from home depot (lowes also has a blue version) and the wing is 1/4 inch fanfold foam from lowes.
rcfreaky101 on October 18, 2013
Thank you very much
llharper on October 20, 2013
Very nice. I like it!
DavidR8 on November 1, 2013
Hey Ghostrider, nice plane. I d like to build one but I can't get your plans to download from your media fire account.
High Wing Trainer
