Hi guy's for those of you who know who we are we are a review channel similar to Flitetest but with 14 & 15 year olds, I'm just requesting some advice from you guys who may know about bomb drop stuff, as in one of our latest video's we are going to have some crazy things going on.
So i've pulled out an old plane and found some decent servo's onboard
The poor old bird wont fly again so I thought these servo's would work a treat!
I've got an orange rx and was wondering the best way to rig this to power when an esc isnt needed?
Any idea's message me!
cheers fella's
If twan1997 is right that you could also use a 6volt battery pack, then you could just use 4 AA batteries (in series). Make sure you hook up the battery pack so the positive and negative are plugged in correctly. It doesn't actually matter where you plug it in. Just a pair of pos and neg at the same port (throttle, elevator, aux, battery, etc.)
Thanks!
But let me understand why do u need a separate power input if u can use he bec on the esc?
I just made my cargo, u can check on my page, and a made 2 release system , one is for the back door and another for a glider release on the top.....
if you don't want to wait for shipment you can try and make the Y connector yourself or solder the BEC directly.
you can also use old ESC that have BEC.
http://www.ehcsystems.com/shop/index.php?act=viewProd&productId=3
Joe :)
