Building around a swappable fuselage design, Josh and David create their own glider designs.
Both of the designs were created using cheap dollar tree foam board.
Flite Test viewers submitted challenge ideas and the gliders were built around those suggestions.
This glider is now available as a Speed Build Swappable Kit! Check out the web store or click the link below to download the free plans and watch how to build your own!
Thanks again for all of your support!
As you may know, Ed at EXAirines has some great ideas for wing designs that break down. Perhaps there could be a swappable wing concept where a Bixler sized wing and a Windestal Thermal wing could be swapped on a common fuselage??? Also, if these do go on to be marketed, make sure you work up a part number for "The Chad Launcher", so people can order Chad to come and high start their gliders. :)
While most wal*marts seem to carry the $3.50 carbon fiber arrows, not all of them do, including the one near me. Shipping from an on-line retailer was cheaper than gas to the nearest wal*mart that had them, so that is the route I took.
It is worth noting that a carbon fiber arrow shaft weights practically nothing compared to a sheet of foam board. A typical sheet of foam board (with paper but no tape) weighs about 140 grams, while a carbon fiber arrow shaft weights only about 15 grams.
Can not wait for plans Awesome.
he does some cool stuff that is glider related.
Thank you for making this hobby fun =D
http://www.youtube.com/watch?v=Uee0VZNxIFo
it was a lot of fun
Really, really want.
Keep up the great work, and thank you.
Paul
email paul@rexshort.co.nz
As the plans are online now I would really like to build one myself, however I do not know how to get my hands on "dollar tree foam board" I live in the Netherlands and do not know if we have a dutch equivalent for it??? As I see in the build video it seems to be foamboard with paper glued to one side, is this correct? Anyone any suggestions?
Thnaks and keep up the fun and good work !!!
Ton. (ceramic999@gmail.com)
Thanks
Ton.
