Gingerbread Baby Blender
by kpd | January 21, 2014 | (9) Posted in Projects
This winter I built a baby blender from gingerbread. The dough is very soft and it tends to crack when I attempted to bend it for the turtle deck. It turned out to be much more challenging than anticipated. There were a couple problems that resulted from the fuselage being too long for the oven and pans. Instead of hot glue I used royal icing to fasten it all together.
This is the fuselage all cut and laid out. I had to use two pans to fit it all. On the right side I used barbecue skewers to support the overhanging dough. As you can see that clearly didnt work. Before I baked it the dough was supported, but as it baked the dough seeped through the skewers. That ruined the rear part of the fuselage!
This is what the rear of the fuselage looked like. Clearly ruined I decided to just cut this part off and account for the shortened fuselage. It reminds me of bear claws. Some of the gingerbread fell between the skewers and caught on fire in the oven!
It is now really short but that doesnt matter. It just means more frosting to hold the tail section together. Time to build the wings!
Both  wings are done now. They are just like the baby blenders but a bit smaller because gingerbread is very heavy and I didnt know if the plane could handle the full size. The gingerbread really rose when they baked which concerned me. The wings are about 1/4 inch thick which was not according to plan. I did not get a picture of the wing struts but they are the same as the baby blenders.
Time to start constructing the fuselage. This went suprisingly smooth compared to how the build had been going. I used alot of frosting and then braced it with two heavy glasses. I wanted to make sure it was strong enough to hold the wings so I used plenty of frosting.
Then i finished the fuselage and fastened it to the bottom wing. I made sure to have enough weight on the fuselage so it would form a strong bond to the wing.
Next the top wing and tail section were put on. I poured caramel into the struts to give them a cool look. The turtle deck was tricky because I had to bake the gingerbread first and it did not want to fold without cracking. With a lot of patience and burns I got the 300 degree gingerbread to sit happily on the formers. The gingerplane was so tail heavy at this point I needed to keep the glasses on the wings so it didnt tip over backwards. It was now completed but very ugly. It needed multiple pounds of candy and some floats to fix that.
That's better! I put floats on it because I didn't trust gingerbread wheels to hold up this 5 pound monstrosity. The water is actually caramelized sugar with blue food coloring. With all the candy on the plane I think it looks pretty good!
Santa turned out to be a really good pilot!
All in all this build was a lot of fun. I enjoyed the whole process even with the setbacks. I encourage you to go and make a gingerbread plane because they are a lot of fun and if you mess up at least you can eat it. You can't do that with foamboard can you! I hope you liked it and I will make sure to post the video of me smashing this plane as is tradition in my family.
Hunter Staples on January 22, 2014
That's Awesome!!!
Widkin on January 22, 2014
Absolutely brilliant! Well done :-)
onemoreflite (John Michaels) on January 22, 2014
Love it!!!
TehMaxwell on January 22, 2014
Awesome, thanks so much for sharing!
Andrew C. on January 22, 2014
that is probably one of the funniest things i have ever seen tell us how it tastes
rcperson123 on January 22, 2014
will it fly?
kpd on January 23, 2014
I will find out soon! I am going to throw it off my roof. However I am pretty sure it will plummet to the ground! It will be really fun to watch it crash!
RotateB4TheEnd on January 22, 2014
Very creative! Better than a normal gingerbread house!
OCD RC on January 23, 2014
What incredible work, i made an account just to comment on this gingerbread plane. Great job, i love gingerbread. I was thinking replacing the Swedish Fish with Gum Drops might give you a bit more lift, but a respectable showing nonetheless.
Thanks! I think it needs more than just gum drops haha!
kmdude on January 24, 2014
WOW that's amazing a lot of work went into that , I can't believe you going to try and fly that after all the work you put into it, do you know how many hours it took, and the final weight of it .post a pic of it landing too.
kpd on January 24, 2014
Thanks! It took around six hour of building and A LOT of drying time. The icing took a couple hours to dry. In the end it weighs around five pounds. I will definitely post a video of the flight!
Gryf on January 24, 2014
Being a guy, I think I'll make a Spitfire out of bacon. Then I'll take it outside and see if it will fry. I mean, "fly".
Yogenh on January 25, 2014
Looks like it took a lot of work!! Don't know if I could eat it just too good looking
