I decided to combine the Noob Tube by: http://www.youtube.com/watch?v=8xk9ecvgkU0 with the Versa wing. The fuselage is not as high. I lowered the 3X3" to 2.5X3. Needed that low profile I think. The gear are those for the Hellcat posted at Flitetest and the engine mount is made on the fly(pardon the pun). The rest is pretty standard although you will note I had to add some support to the wing on the bottom to glue. It is an extra piece of foamboard that extends out about an inch on both sides. the wing is then glued down and across the top. The hatch is Noob tube inspired for the electronics. Tell me what you guys think???
Could you share a video clip detailing the modifications you made to the straightening iron and your technique for beveling edges? Could this also be used to create tapered trailing edges?
Nice Stephan.... and Thanks for Sharing..... I will have to search and catch up with your posts... lol (its September, 2016, and I just only now found this in a Versa search)
roflmao
Fly fast, take chances, see magic smoke escape... it's only foamboard!
miggy
