Final Dump File – RadioMaster TX16S and RadioMaster Zorro
Dump file sets up the basics for the Gremlin Guardian, including receiver, arm, and modes
Gremlin Guardian is setup for RadioMaster R81 under ports tab
Airmode is on by default
Arm is setup on Aux 2 (determined by enduser transmitter config)
Modes are setup on Aux 3
Modes Available
Acro – Expert flying mode with no accelerometer assistance
Angle – Beginner mode with accelerometer assistance and limited to 55° on pitch and roll axis. Will auto level on neutral stick input
Horizon – Intermediate mode with accelerometer assistance. Not limited on pitch and roll axis. Will auto level on neutral stick input
Expo added to all Axis to smooth out center stick range
Pitch and Roll - .25 Expo
Yaw - .15 Expo
Receiver Config setup and ready to go
Final Dump File – RadioMaster T8 Lite
Arm is setup for SA switch on RadioMaster T8 Lite
Arm – SA High (toward front of transmitter)
Disarm – SA Low (away from front of transmitter
Modes are setup on SC switch on RadioMaster T8 Lite
Modes Available and switch positions
Acro – SC Low (away from front of transmitter)
Angle – SC Mid
Horizon – SC High (toward front of transmitter)
Yaw - .15 Expo
Final Dump File - RadioMaster Zorro
Arm is setup on Aux 1 (determined by enduser transmitter config)
Modes are setup on Aux 2
Modes Available
Yaw - .15 Expo
No Comments Yet
Be the first to leave one!
