The Story
I bought the 3 pack Speed build kit a few months ago but haven't really done anything after a disappointing experience with the Nutball. Everytime I got the plane in the air, it would flip on its right side, and nose dive to the ground regardless of hand launching or taking-off from the ground.
I was fortunate to have a few AMA chartered clubs nearby. I joined one which had a member with experience flying FT planes. He took a look at the Nutball I built and noticed the wing was badly warped. The prognosis was that it would never fly straight. So, I decided I would give the FT Flyer a try since that's what he was flying and showed me its abilities. I was excited and couldn't wait to get started.
In the meantime, I was taking weekly lessons on a .40-size nitro trainer with a buddybox and an AMA certified R/C flight insructor, all a part of the club membership. This combined with many hours on Phoenix flight sim, I had become very comfortable with 4-channel flight. In fact, I had been doing inverted flight, knife-edges, etc on the flight sim for 2 years but was learning to fight the fear on the real thing!! It just ain't quite the same!
The Reason
I finally finished the FT Flyer and took it to the field on a very windy afternoon to try it out. I knew it was way too windy to fly a plane like this, especially with my lack of experience! The maiden flight was scary as the plane shot high into the air really fast upwind and was almost uncontrolable downwind It was too windy and I wasn't reacting fast enough. Also, I kept trying to fly it like a 4 channel plane and was having a hard time making up for it's lack of response. I just kept saying to myself, "if it only had ailerons!".
On the way home, I kept looking at the back part of the wing trying to figure how to add them. After several raindy days of thinking about it, I grabbed a metal ruler, X-Acto knife, 1/2" pliers and wire cutters then measured, bent and cut. I removed 3 1/4 inches from the back of the wings to make for more traditional ailerons.
I put the original servos on the sides and two Turnigy 9-gram, metal gear servos on the wing, 3 inches in front of the previous location and took the cutout foam to seal the hole left from the original servo location.
The Results
Tail HEAVY!!! I've tried to balance it out but it means adding so much weight to the nose that the plane is alomst 50% heavier!
Unfortunately, the weather has been really bad here so I haven't had a chance to get it in the air to find out how it (bad) will fly.
So much for my novice engineering work! Still, it was a lot of fun and I can easily create a new one with better modifications.
At least, it's a start into a new adventure of building, flying and modifying.
Thanks!
Thanks to the Flight Test team. You guys are a blessing and your well produced videos make my day as I laugh at your antics. ... nice to watch after a long day at the office! Having co-owned a post-production company in the past, I know quality stuff when I see it.You guys rock!
Most of all, thanks for helping make the hobby fun, affordable & accessible to the masses!
Thanks to all the other followers who inspired me to attempt a mod in the first place.
My variants are here -
https://sites.google.com/site/kayakamf/rcplanes/dart-xs
https://sites.google.com/site/kayakamf/rcplanes/dart-xs/darthawk
I'd also be interested in knowing exactly how heavy your Flyer has become - mine uses heavier foam board and comes-in at 445g with a 1000mah battery. It flies fine! See it here; http://www.flitetest.com/articles/don-t-let-heavy-foamboard-get-you-down
If you really are significantly over that weight then you do need to shift weight forward and my advice on servo location will fix that easily. Looking forward to the flight video!
Here's some initial reactions regarding weight and balance that could sort things very quickly - scrap the two rear servos operating the rudder and elevator - instead lead pushrods to the two servos you've got operating the ailerons. Then mount a single servo further forward (well beyond the CG) to operate the ailerons. (See this in the Baby Blender build and the FT Bloody Wonder. Your need for excessive weight forward will disappear and the total weight of your plane will drop significantly - all to do with 'moments'. See my article 'The triplets and the see-saw' to see how small weights magnify their effect due to the length they are from the balance point. Also these Right angle bends in the pushrods will 'spring' - losing you some of the servo motion and control. A little bending to lead the pushrods is fine, but this dog-legging will just introduce play. I've seen (and used) little vee bends in pushrods (used to adjust motion) but they are very compact and stiff. I can see this being a fun plane to fly system used once you get the kinks ironed out - best of luck!
Cheers, alibopo.
Results: moving the wing solved the CG problem but I got the wing tilted too much so the ailerons helped keep it level at best. It was a priceless learning experience.
My servos are mounted in about the same positions as yours are and that's the same position on the 3 Ch version. On the 4 Ch, I cover the top servo with a canopy, makes things look much better. On one of the standard Darts the Rx is under the canopy.
I was out this afternoon and the battery fell out. It wasn't immediately obvious and the plane landed quite happily without my input.
