FT F22 Build
by Pauloar | January 22, 2014 | (0) Posted in Projects
Hello guys,
I want share my new scratch build for the new F22 FT design!
Check it out some photos below! I had made just a "extra" air inlet for the F22......
Material was Depron 5mm,
I Hope you guys like it!!!!
:-D
 This Firewall I have made with 3 MM hard cardfoam +plywood!!! I stood really nice and it works perfectly!
alibopo on February 5, 2014
Hi - very nice innovation on the motor mount! Be sure to treat it with varnish or paint to waterproof and stiffen/strengthen the card. Amazing how much stronger card and paper gets after varnishing. You'll let us know how it lasts? The only weak point I see is the wood panel on the front. - this isn't actually plywood and I can already see a split at the top there. Pre-drilling the screw hole with an undersized bit helps, so that the wood doesn't have to spread as much. OR just drill it out and use a nut and bolt with a big washer on the cardfoam side to help spread the load. If you can't find ply I found that MDF (medium density fibreboard) works reasonably well for firewalls. No grain, so it never splits. Nice build though :)
Pauloar on February 4, 2014
Thanks for the nice comments.
I have thought to decrease the air intakes to increase the air flow inside my ESC, I am using a 30A from hobby king which is heating a lot..... :-(....... and besides I thought that would look nice!
:-D
I wil try to make it the flying video as soon as the weather in Germany helps.....
Thanks man and take good care.!
#3 on February 4, 2014
Looks great nice sharp cuts on the exposed edges,why did you modify the air intakes,are you going to do a flying video,thanks for sharing
Foamkiller on April 10, 2015
Great plane easy to build and easy to fly please check out my F-22 Raptor video
https://youtu.be/OE2cP553ZCc
FT F22 Build
