FT-3D Armin High wing MOD Review
by EndoftheRoadRC | May 28, 2013 | (5) Posted in Projects
After interaction between my FT-3D and a light pole (no video = / ) I removed the mid wing and added a classic 40" Armin wing in a High Wing configuration.  The top access hatch was shaved off, the wing mounting, servo, and power pod holes patched and skimmed with hot glue, and a access hole added to the front for the battery.  Wing attached with BBQ&bands.  Simple mod for an entirely different experience.  This version is still 3D capable and crazy fun to fly.
sailorJohn on June 1, 2013
I 've got ten different planes using Armin wings (bipes , low wing , high wing ) still the best wing I 've used . Flys ok inverted and doesn't seem to care if it's windy (good thing this year), I wonder how it would do midwing FT3D
EndoftheRoadRC on June 2, 2013
I agree the Armin wing is tip top. My next version will move the Armin wing into a low wing config. on the Ft3d, might have to make the last stop in the middle
sailorJohn on June 4, 2013
I 'm doing the same thing but do to laziness, and since I have the parts already I'm thinking 5 in cord with 30 in wing span. Anybody want to do the math for wing loading?
Russ40 on May 30, 2013
Nice flying. Love the flying between the trees.
EndoftheRoadRC on May 30, 2013
Thanks Russ
If you buy the kit , trace it on construction paper for easy rebuild.
jerimiah85 on May 31, 2013
You sir have a good idea. I am now heading to dollar tree for more foam. Handles like a high wing trainer thanks for sharing.
You betcha, and ya that was the idea for use as a trainer, works great, needed to shift the battery placement back a bit
