In today's review we check out the FPV584 Plug and Play 5.8 GHz 400mW Wireless System from Hobby Wireless. We check out the entire system from what you need or don't need to wire it up and installing it on your plane or quad. We then put it in the air and give it a test flight.
This is a great option to those whom want to do FPV without interference problems with 2.4 GHz R/C radios.
The 400mW 5.8 GHz transmitter and receiver are capable to go take your audio and video wirelessly.
The tiny pocket size receiver besides its small size, it also comes with two (2) A/V outputs to easy connect two video displays or 1x video display and 1x video recorder simultaneously.
It's great and reliable system, with all the important features that plug and play systems must to have.
Note to use any other antenna besides the original an RPSMA adapter is needed.
More details on the system Check out Hobby Wireless
http://hobbywireless.com/index.php?main_page=index
FPV584 Plug and Play System.
http://tinyurl.com/a6f4att
Transmitter's features:
- Output Power:400mW
- High grade switching regulator.
- Built-in microphone with volume control.
- Working voltage: DC 7.2 - 12v (9 - 12v performs better)
- Camera port output voltage (will be the voltage used to power the transmitter -0.5V)
- 8 Selectable channels: DIP switches
- Working Frequencies: CH1:5733 - CH2:5752 - CH3:5771 - CH4:5790- CH5:5809 - CH6:5828- CH7:5847 - CH8:5866. (Not compatible with old version receivers or AIO glasses).
- Current consumption: ~280mA
- Digital phase-locked loop circuit, no channel drift issues.
- High quality noise filtering circuit.
- Regulated output voltage for the camera.
- Low profile circuit board.
- All Molex type of lathed plugs for safe connections.
- Dimensions:14 x 26 x 39 mm (0.45" x 1" x 1.5" inches).
- Weight 26 grams (0.9 oz).
Receiver's features:
- R5800 Dual (2x) Audio and Video outputs.
- Working voltage: 8-12 VDC (runs cooler with 8V)
- Current consumption: 120mAh
- Dimensions:13 x 52 x 60 mm (0.4" x 2" x 2.5" inches).
Includes:
- TXV584 5.8 GHz 400mw transmitter
- Weight 48 grams (1.7 oz).
- R5800 5.8 GHz pocket size receiver
- Transmitter's power plug with leads
- Receiver's power plug with leads
- Receiver's A/V out cable with RCA plugs
- 2x 2dBi whip antennas
- 12 volts camera with a plug and play cable (Futaba connector type) can be added to this combo. (see below for this option).
Please Subscribe, Like & Comment
Build, Fly, Crash, Repair, Repeat.
Find us on Facebook. https://www.facebook.com/StoneBlueAirlines
Flying Buddy:
iBcrazy on youtube :cagreve1231
My Gear:
FPV Gear:
http://videoaerialsystems.com/
http://onlyflyingmachines.com/
http://www.securitycamera2000.com/
FPV Camera:
Sony CMQ1993X
Video:
808 #16 Keychain Camera modded lens.
808 #16 V2 D Lens
Planes:
iBcrazy Spector
iBcrazy Raven
FPV48 Scratch Built EPP Wing
Flight Test Nut Ball
Quadcopter:
Lotus T380 5.8ghz
DJI F450 KK2.0 V1.5
Scratch built T-Copter
Radio: Futaba T7Cap 72mhz
Spectrum Dx6i 2.4ghz
Receiver: Coronal RP6D1 / RP8D1 72mhz
Ground Station:
1.2 Ghz Tx & Rx
Helical & Cross Hair Antenna
Viewing:
Vuzix Wrap 920 Goggles
Vuzix Wrap 1200
7" LCD BEV-OFM
DVR:
Hobby Wireless VR1500
Great Stuff on YouTube:
http://www.youtube.com/user/flitetest
http://flitetest.com
http://www.youtube.com/user/experimentalairlines
Flying Wing Calculator
http://fwcg.3dzone.dk/
T- Copter Calculator
http://tinyurl.com/bn2zjs2
Free Flight Sim for PC.
http://www.rcdeskpilot.com
Music:
www.freeplaymusic.com
www.stoneblueproductions.com
info@stoneblueproductions.com
Photo-Video-Marketing-Design
If its ok with you I added this as a related article in my easy dirversity article. In advance thanks.
And fell free to add my article as related if you want.
