FPV49 v3 Scratch Build
by RC Test Pilot | December 18, 2013 | (7) Posted in Projects
FPV49 V3
This is a build of the FPV49 V3 wing who FPVTrond designed, It's made out of 6 layers of 6mm white Depron.
It uses a wing design called Kline-Fogleman airfoils also known as KF or KFm. The wing is build for high speed FPV, so it uses KFm-4 which is a symmetrical KFm airfoil.
The first thing I did was to line up marks on the depron. Depron is very easy to cut in
I recommed to change the blade often.
FPVTrond also made a build video of it with all the information you need to build your own.
All the depron pieces cut out.
In the center off the wing I placed some alu pipes to make it very stiff. You can also use flat carbon spares.
Time to cut the leading edge. To Bevel the edge you can just use sandpaper or a sharp knife.
All the electronic placed on the top of the wing.
For the Battery holder I just used some 4mm plywood and a dremel.
I didn't want to spend a lot of money, so I manged to cut the Gopro and FPV camera bay out of the 4mm plywood.
Painted black so it looks cool
The ailerons is also made out of depron with a carbon in the middle and yellow packing tape outside
The motor mount is just three plates of plywood glued on the depron and a bolt in the middle
I removed three layers of depron for the batttery to fit on and glueed it with hotglue
I covered with black, yellow, tranperant tape.
Here is the finish result of the wing.
I just had the maiden flight to day and it flew like at dream. I really recomment it to people who want a easy to build wing for FPV.
Thanks to FPVTrond for the Awesome Design
  • http://flitetest.com/authors/FPVTrond
  • https://www.facebook.com/fpv.trond
  • http://www.youtube.com/user/FPVTrond
- See more at: http://flitetest.com/articles/fpv49-v3-build?preview=1#sthash.wnJqmlLN.dpuf
liveyourdreamsRC on January 20, 2014
I just found the FPV49 series yesterday, and it looks really cool. Nice job on the build. Please post some flights of this bird! Also you should send some pics or footage to Trond because he is making that collaboration video I think. Check his youtube for the video and info. Again nice job and I hope I can start building a wing soon.
RC Test Pilot on January 24, 2014
Thanks for the comment. I can´t make any video at the time because of the weather, but I will make one as soon I can.
rcflyer729 on January 21, 2014
nice job what motor are you using
i´m using a NTM Prop Drive Series 35-36A 1400Kv / 550W motor
rcflyer729 on January 24, 2014
thanks what size prop
RC Test Pilot on January 28, 2014
10x6 APC Prop
I love planes when I was young on April 16, 2015
Nice work!
bibbox on January 9, 2017
hello and congratulations for your work. I'm performing his project but would like an account if I put a battery from 5200 3s lipo can 'go well? thank you Giovanni.
