FPV31 Flying Wing Plans
by FPVTrond | September 14, 2020 | (2) Posted in Projects
31" Scratch built FPV flying wing made out of depron and carbon rods.  Incredible stable for high quality FPV footage!
The wing is made out of one sheet of 6mm depron. It has 3 main layers 6+6+6mm and a middle bay large enough for a 4S battery.
This is the successor of the FPV49. All components has been built into the wing for a more true KFm-4 airfoil.
How to cover your plane in packing tape: http://www.youtube.com/watch?v=PbyVGfB1oCg
Please don't hesitate to make suggestions for improvements :)
How to launch this plane: http://www.youtube.com/watch?v=FxlA2RQOeGQ
Link to some equipment used Savöx Servo Micro SH-0257MG https://www.amazon.com/Savox-SH-0257MG-Super-Speed-Digital/dp/B004K3BVYM
Control Horn,27x20mm https://www.banggood.com/custlink/GvKYcUDcZc
Motor [Emax RS2205-2300 2205 2300KV] https://www.banggood.com/custlink/3KvYCzmr8i
ESC (20-30A) [Favourite FVT LittleBee 20A OPTO PRO] https://www.banggood.com/custlink/GKmEckvp9j
TBS Unify (with U.FL antenna to save weight) https://www.team-blacksheep.com/shop/cat:fpv_5g8vtx#product_listing
RunCam Phoenix 2 https://www.banggood.com/custlink/mKDdJqmC9k
RunCam Split 3 Micro https://www.banggood.com/custlink/KGKhJzGCS7
Diatone Mini 2A BEC V2.0 5V https://www.banggood.com/custlink/vGKYpqGply
Diatone Mini 2A BEC V2.0 12V https://www.banggood.com/custlink/vGKYpqGply
Strobon NEO - RGB LED Strip Controller for RC https://store.flytron.com/products/strobon-neo?_pos=1&_sid=781cbc9ad&_ss=r
Diatone RGB LED Board SW302 https://www.banggood.com/custlink/GKmYWkKpjt
5.8Ghz Antenna U.FL RHCP https://www.banggood.com/custlink/mKDRWkmCll
Flight Controller (OSD, Current sensor, SD card) https://www.banggood.com/custlink/m33EJkKJlU
GPS https://www.banggood.com/custlink/G33YczvWgD
JST SH4 https://www.banggood.com/custlink/K3KYW2GW4y
JST SH6 https://www.banggood.com/custlink/3mmyJM3J6r
FPV31 Templates.dwg
FPV31 Templates.dxf
MAYAWING BAY FINAL (covers).stl
MAYAWING BAY FINAL (main bay).stl
MAYAWING BAY FINAL (side bays).stl
Motor Mount.stl
Some sample video from flights:
shiva75 on April 9, 2021
Wonderful ! Please, can you share plan (pdf) same fpv49 ?
Very very good Work. I print tomorrow the first part.
FPVTrond on September 4, 2021
Hi Shiva, pdf is in description of video linked
shiva75 on January 28, 2022
Thanks Thanks Thanks.
