Greetings Everyone!
I have finally finished the free plans and build video for the FPV Starchaser! I have put the plans in PDF format and they are tiled plans, so that you can print them out on your home printer. They are aligned by overlapping the pages and aligning up the "X"s, or crosses. I would recommend using thinner typing paper, it is pretty transparent and allows for easier alignment. Make sure you set your printer on borderless, or full page.
The video is part one of two and will present the build of the plane sans graphics and electronics installation. I hope to have part two, the graphics and application video in about a week, but if you decide that you do not want to use the graphics feel free to paint your plane and install the electronics however you like, the design is pretty open to customization!
If you wish to wait for the graphics that I have designed for the plane I will also have a section in the video on how I have installed my electronics and FPV set-up.
Thanks for checking out my design and happy building! Starchaser Plans.zip
Thanks
Kevin
I may be able to put the plans together as a large PDF, I will try to work on it this weekend and let you know.
