I started off this project as a prototype build for a UAV/Drone contract that one of my aquantances acuired to do Aerial photography.
The requirements were to build a plane that could fly an extended distance with a payload of up to 1000 grams.
so what happened.... I built a foam glider..
Here is the 1st 3 flights.
The Material used is 2 A1 sheets of 3mm foamboard, a 70cm 5x20mm hard wood beam as a wing spar,
2 x 100mmx6mm wooden pins for the rubber band holders of the wing.
4 x 9gram servos.
Outrunner motor with 1.1Kg thrust with a 10x4.7 APC propeller
I use a 2200mAh battery and a 20Amp ESC.
I have now flown the plane in ideal conditions and it handles extreemly well, I can glide without thermals for 5 minutes from an altitude of about 300 meters only working the head winds.
With the current setup the glider can sustain altitude and fly at 10% power, I am estimating to get about 60 minutes of flight at that rate.
Here is my latest Video:
The prototype plans can be found here:
https://drive.google.com/folderview?id=0B73hvPNPBVHpaVJNcmM5Ykt1M0U&usp=sharing
I do like the POV flight stuff, but I also like to see the plane in flight and how it performs and handles.
Cheers.
Here is a late build image in the meantime.
https://pbs.twimg.com/media/BW18IhDCUAABOJ7.jpg
I could never find anyone to film for me either so I bought a set of those camera spectacles. They're no good for distant objects but fine up to about 100m. I can usually patch together enough 'close' flight time to make it worth posting. The only thing you have to remember is to 'head-track' to keep the camera in line with the subject. Other than that it's pretty much wear and forget.
You can expect the new plans up in 24h.
The original link will still be valid to my public google drive share for this project.
The fuselage Plans now include the tail section that I left out by mistake.
Have fun!!
http://youtu.be/ufF7yEWWEQ8
There is an issue when I export from Draftsigt that does an auto fit action, please download the DWG files and do a direct print from the plans.
http://www.3ds.com/products/draftsight/download-draftsight/#xtor=AD-508-[swfreetools]-[middle]-[intext]-[www.solidworks.com]
