ANIMALS MADE FROM FOAMBOARD WITH FREE PLANS
I started to have a build up of foam board off cuttings after makinging planes and I did know what to do with them and my little brother was wanting me to make some animals from them so here they are.
This is a 25cm/10inches wide spider that I decided to make. It is very easy to make and can be made from anythickness of foam board and posibly even card board. I have created some plans for the spider which are linked below if anyone would like to make one. To make it all you need is some foamboard, glue, acrylic paint and a pair of sciccors or a hobby knife.
Spider Plans
Here is the build video.
The fox
I also made a fox that is 74cm/29 inches long. I made it by drawing an outline of a fox on and A2 piece of paper i then put this on the foam voard and cut around it. I then cut two smaller body pieces out and put some supports on the inside to make it wider. This was a one off scratch build so there are no plans for this but it is simple to make.
Thanks for viewing
