Long-Distance Floatplane Flying From a Motorboat
by ultramicrobe | September 8, 2014 | (19) Posted in Just Fun
Long-Distance Flying From a Boat
The Pacific Ocean is really, really big it turns out, which means unlimited space to fly, if you have floats and a boat to follow your plane. On a recent salmon fishing trip off Cortes Island in British Columbia, I took along my Multiplex FunCub equipped with floats and a GoPro and discovered the fun of flying long-distance line-of-sight from the speeding boat.
Here is a video from a couple of trips to a seal colony covering more than 20km. There are some high-altitude clips, some boat-chasing, and some shots of the seal colony we visited. Below I describe the trip a bit, and also describe the set up of the plane, floats, and camera.
Here is anothe movie, just for fun, that is just some nice shots from floatplane flying around the Northern and Southern Gulf Islands of BC. This is either flying from land (and taxing back after landing), or in a few cases from an inflatable kayak).
The first movie is actually from two days and the total distance traveled in the boat following the plane was about 20 km (‘as the crow flies’, but much longer as a FunCub flies because it is so much faster than the boat so I was doing circles around the boat). The conditions were pretty breezy, and most of the flying in the movie took place with a decent cross-wind. The plane was hand-launched from the boat to keep the lens dry for the subsequent flying. I would fly for about 15 minutes, find a nice patch to land out of the waves, touch down to replace the battery, clean the lens, and take off again.
Heading out to go fishing with my FunCub.
Bird’s eye view of the local scenery. Endless free space to fly.
The tiny little boat (at the bottom) is where I am flying from.
Touching down to change a battery.
This is the seal colony we visited, where we often see seals or sea lions. They slide into the water if you get to close in a boat, but were not bothered by the plane. (they are on the lower right)
Chasing the boat.
I spent a lot of time low to the water chasing the boat. The plane was quite a lot faster than the boat, so you can see the flaps often activated to slow down. Low passes beside the boat were fun and also challenging with the cross wind, and at low power the wind often pushed me out over the bow of the boat. A few passes got really close.
The final stop of our flight was Whaletown, Cortes Island, but the trip also took in took Subtle Islands, Plunger Pass, and Centre Islet, where the seals were.
My FunCub Setup.
The Multiplex FunCub is a classic, and really does almost anything you want. Mine is set up with a Turnigy Aerodrive SK3 - 3536-1050kv motor and 12X6 APC prop. I usually fly with a smaller 2200mAh battery since I have lots of them. I painted it the same ‘school bus yellow’ used by a lot of search and rescue and trainers, which is and absolutely amazing colour for visibility and orientation. It has two broad black stripes on either wing (2X width black packing tape), which are also very good for orientation. I can fly this plane pretty high line-of-sight without loosing orientation. The only modification from the stock I made is an addition to make the tail removable with a nylon thumb-screw (see pictures).
Wide black stripes are great for orientation.
The tail was modified to allow it to break down. I made a M5 threaded T-shaped piece of UHMW plastic and glued it onto the vertical stabilizer, then drilled a corresponding hole inthe horizontal stabilizer and fuselage.
The front of the horizontal stabilizer also has a popcicle stick that slides into a slot in the fuselage.
The hole in the fuselage is reinforced with a bit of tube to allow the thumbscrew to be tightened.
Slide the whole thing onto the fuselage, and then just tighten with a single M5 thumbscrew (and hook up the pushrods). Plane goes back into the box disassembled.
The camera is mounted on the wing, which actually gives what I think is a nice side view. I made a simple mount using two nylon bolts and it can be swapped to either side.  The camera gets some splash on take off and landing (the 12” prop kicks up some water), so I hand-launch when I want to do a movie, otherwise you end up with salty water drops in front of the lens. You also have to remember to clean this after each landing. Hand-launching from a boat means lots of throttle since you have no room for mistakes, but the FunCub basically flies out of your hand without any effort.
Side-mounted GoPro. At the widest angle you get a bit of wingtip but no floats or wheels.
The floats are Hyperion. They are not quite big enough for a FunCub with a GoPro (it lists badly), but are adequate for the job, and have a great mounting system. Not only do they come on and off very quickly (when you want them too), but the attachment between struts and floats is very sturdy compared with all the others I have used. I use them on snow a lot, which can be hard on the attachments, but these are tough. For modifications, I use bicycle inner tube rather than elastic bands, I put some piano wire under the attachment site to hook the elastics on to (stronger than the plastic tube it comes with). I recently added 6mm depron to the underside to improve the buoyancy.
Hyperion floats. Not pretty, but they take a beating and break down easily.
The simple connection system is very strong. I use bike inner tubes as elastics and reinforced the connection with a bit of piano wire.
The floats friction-fit into two wooden blocks. It is tight but easy. I re-inforced around the blocks.
Don't forget you NEED a water-rudder. This easy one attaches by inserting a skewer into the rudder, and wrapping a bit of bent piano wire around the wheel. Then tape around the wire/wheel with duct tape. Without a rudder you will have trouble taxiing, especially in wind.
Saltwater is hard on planes, there is no way around that. I keep the pushrods oiled and try to rinse it a bit after flying. My ESC and receiver were soaked in Rust-EZ, a chemical boaters use to preserve metal and electronics from salt. The pushrods are going though, so I will have to find stainless replacements. Even the aluminum pushrod connectors are unhappy, so you need to keep up on the maintenance.
Overall, I HIGHLY recommend trying this for the sheer fun of it. Flying gliders in the mountains is also really fun for the adrenalin rush, but this is really one of the best experiences I have had, and is a lot less likely to end with a missing or ruined plane. I never tried this with FPV (because I did not want to get the gear wet), but if you protected the electronics this would be a fantastic experience too.
AkimboGlueGuns on September 8, 2014
This is awesome! I recently became interested in water flying, and this is one of the coolest articles I have seen to date on the subject.
chadrat on September 8, 2014
As always Patrick, great article! Floats have been fun for me as well and I totally want to try the boat chase option. Agree FPV would rule, but I have already lost one set of gear in a salt water crash and am not confident I could waterproof it to survive... But maybe we can figure it out!
Great job - keep the article churning!
apnewton on September 8, 2014
Brilliant. Great article and fascinating place to fly.
rcspaceflight on September 8, 2014
You, sir, are living the dream.
ultramicrobe on September 8, 2014
Well, not everyday is exactly like that, but it was a good day. We even caught two nice Chinook.
OrangutangSurfer on September 10, 2014
beautiful footage and an awesome video, i'm more convinced I need to put floats on one of my planes for the next time we take the boat to the lake!
ultramicrobe on September 12, 2014
Hi,
That is a great comment to hear - I guess the whole point of this site is to get people excited to try something new. Water can be intimidating, but if you have a good plane that you are used to it is easy flying. If you look at the bloopers at the end of the second video you will see some crashes. Underpowered planes, but no harm done.
KiwiRCFlyer on September 10, 2014
Brilliant use of one of my favorite bands. Good choice of lyrics.
"Gravity, release me
And don't ever hold me down
Now my feet won't touch the ground"
sailorJohn on September 10, 2014
Good rating because you gave information about the plane
pekote on September 12, 2014
Really nice videos!! You also include some bloopers!!
You have god taste for video editing, also considering that you flight in 3rd person view which makes more difficult to take good shots. 5 STARS!!!
ttprigg on September 12, 2014
Great subject (and editing)!
Canair on October 2, 2014
Just brilliant mate.
Timwetzel on February 15, 2018
This is amazing! Your profile and post interest me so much!!!!!!!
