Here's what you can build with Flight Pack F along with other details you might find helpful!
Our Flite Test Flight Packs, stuffed full of electronic-y goodness, are a super easy way to get everything you need to build a DIY airplane. In RC, sometimes things are a little complicated for beginners, so these packs really are a shortcut to success. They make sure that you have everything you need along with ensuring that it's all compatible. Here's everything you need to know about Flight Pack F.
What's in the package?
Firstly, let's have a look at everything that you get with your Flight Pack.
Layed out, you have three high-quality micro Flite Test servos, your motor, a bag of hardware (including tools and props) and an ESC.
Inside the hardware bag you'll find two Flite Test branded screwdrivers.
There's also a bunch of extension leads. One of these is a 'Y' harness so you can link two servos together. This is useful if you want to run both off the same channel on your receiver for your wing's ailerons.
The motor you get is a great little Emax 2300KV outrunner. This is a 2205 size which revs very high. This makes it good for some of the faster Mighty Mini's that we produce such as the Mustang and Corsair.
Both the motor and ESC come with bullet connectors. This means that you don't have to bother soldering anything and you can switch your leads around to reverse the direction of the motor extremely easily.
Flite Test Compatible Kits
So what planes work the best with Flight Pack F? Well, the good news is that you can use the pack with almost any of our Mini DIY Airplanes. What the F pack excels at, however, is delivering a lot of power in a small package. It's perfect for wings like the Mini Arrow and warbirds like The Mini Corsair.
Here are all of the airplanes that you can use Flight Pack F with.
- Flite Test Alpha
- Flite Test Alpha Bravo Charlie
- Flite Test Bravo
- Flite Test Charlie
- Flite Test Mini Arrow
- Flite Test Mini Corsair
- Flite Test Mini DR1 Triplane
- Flite Test Mini F-22
- Flite Test Mini Mustang
- Flite Test Mini SE5 Biplane
- Flite Test Mini Sportster
- Flite Test Mini Vector
- Flite Test Mini Warbird Combo
- Flite Test Pietenpol
- Flite Test WWI Battle Buddies
What will you make with Power Pack F? Let us know in the comments below!
Article by James Whomsley
Editor of FliteTest.com
james@flitetest.com
