EZ motor mount for rc planes
by himster | January 10, 2015 | (10) Posted in Tips
The EZ motor mount is a simple to build yet very strong motor mount made from common materials.
TOOLS AND MATERIALLS REQUIRED
THESE ARE JUST THE MEASURMENTS THAT I USE
FEEL FREE TO USE YOUR OWN
CUT THE PEICES OUT
THESE ARE THE MEASUREMENTS FOR THE DIAGONAL AXIS
GLUE THE PEICES TOGETHER
YOU SHOULD END UP WITH THIS
MARK THE HOLES
DRILL THEM
SCREW THE MOTOR MOUNT ON
ATTACH THE MOTOR
THE FOAM GIVES IT THE STABILITY AND STRENGTH THAT THE MOTOR MOUNT NEED IN ORDER TO BE PROPERLY INSTALLED
 AND WE ARE DONE
I hope that this has helped you
Don't forget to rate
rcspaceflight on January 14, 2015
I love this idea. Simple and effective.
I've had a hot motor melt the hot glue I was using to hold it on (for a pusher). Ultimately I burnt out the ESC because of how hot it was running. That isn't that big of a concern.
You should have packing tape wrapped around the firewall and onto the foam however. It's the firewalls job to stay flat with the motor firmly screwed onto it. It's the packing tapes job to hold the firewall to the plane.
dholcomb on January 13, 2015
I just use 1/4 inch ply...
d2it4me on January 11, 2015
Looks good. However, if your run a setup that produces much heat you run the risk of reheating that glue and separating. Won't really matter much on a pusher setup, but with tractor setup your motor may fly off. So maybe use wood glue instead of the hot glue to hold the wood together. Then use extreme packing tape on the pod before screwing the motor on.
Stunt Man 169 on January 12, 2015
I agree with what you said, however if you are running a setup that produces that much heat you need to prop down or find a motor that can handle the current draw. Foam safe CA would make the best glue, but that is also the most expensive. The easiest fix would probably just be extreme packing tape.
ohitstarik on January 11, 2015
Very helpful. Bookmarking!
