Recently my neighbour gave me a load of sticker paper in different colours. He said that because he didn't use them, he wanted me to have them to use for my planes.
Because the decals on my Bixler 2 were mostly gone I decided to cut a few pages into strips and put stripes on my bixler, here's the result (notice my homemade cockpit, I lost the stock one while doing nightflying, if asked I can try to make plans )
A little while later I wanted to make the Ft-racer and realised after building it that I wanted to put some decals onto it. As I wanted to do something a little more advanced I decided to take one of the yellow pages and print something on it. If I only had had the idea to put these pages into the printer earlier I could have made my Bixler alot better looking :/ the end result of the racer plane is looking pretty sweet.
After seeing the Ft-bloody wonder episode I really wanted to make one to do streamer combat and so I did. I went with the following setup:
1300Kv motor
10Amp ESC
500mah 20C 3s LiPo
With this setup I can go vertical and get flight times up to about 4minutes and because the batteries are this small, I can charge one pack while I'm flying and it will be done charging at the moment that I come in. The only problem I am facing is that I cannot fly nonstop due to heat issues XD.
After testflying it I got the idea to make it look as good as it flies. Having alot of stickerpaper without any colour (just white) I got the Idea to print some nice decals onto it. So I searched some pretty nice images on Google.
I found these nice flames and turned them into a Word file
At this moment I put some paper into the printer and made a test print. It looked pretty nice so I printed them on the stickerpaper.
After printing them I started sticking them onto my Bloody Wonder
starting to look sweet
bottom view
finished plane
now I only have to wait until my flybuddy gets here so we can fly this badboy
Easy and inexpensive way to print anything you want! I used this method to cover a super cup with bubbles and the logo of my Carwash.
For me it was real fun to design, print and cut. And no fuss with water decals.
http://youtu.be/by5UyCFmn7Y
how match weight does those papers add ?
With printed decals each paper weight about 12 grams and I used 5 papers on this airframe. it coms to about 60g's extra
After reading your article, I googled and found this material on the internet: Grafix Clear Adhesive Backed Inkjet Film, 8 x 11 inches
MP Code #MP-10917-002.
As mentioned by others, here, you have to "fix" inkjet inks after printing. The Testors kits have a rattle can of fixer. Hair spray sounds like a cheaper alternative, I will have to give it a try.
Cheers - Peter
