This is the E-Flite Vapor. It's an absolutely tiny, ultra lightweight RC flyer capable of flying around your living room. Alex and Josh got to grips with it here in the video review.
So, what can you expect when you open the box of your own Vapor model?
Well, the aircraft is made from a composite of carbon fibre and covering film which makes for a very lightweight aircraft. As Josh mentioned in the video, these materials also allow the plane to flex and bend to take a crash without breaking.
In regards to the motor, this airplane (being a small ultra-micro) has a brushed motor similar to what you'd find on a micro quad. The motor uses a gearbox that helps swing the prop. The high power to weight ratio means that you can not only hover the Vapor, but pull out of a high alpha with ease.
Here's a rundown in numbers of the Vapor's key features:
- Completely factory-assembled and ready-to-fly right out of the box
- Excellent balance of size, weight and performance for flying indoors
- Ideal for flight in small indoor areas such as a living room
- High-Power coreless motor, gearbox and propeller combination
- Ultra-lightweight and durable carbon-fiber airframe
- Industry-leading Spektrum™ DSMX® 2.4GHz technology receiver
- Fully proportional throttle, elevator and rudder control
- Includes 70mAh 1S 3.7V LiPo battery and USB charger
- Transmitter equipped with Spektrum 2.4GHz technology
The Vapor is a great option for you if the location that you fly at during the winter is a gymnasium or large open space like a community hall. Even outdoors, albeit with absolutely zero wind, the Vapor excels as a slow flying, manoeuvrable RC aircraft.
How to High-Alpha
So, I hear some of you saying, what is a high-alpha? It's very simple. When a plane is travelling through the air, it's wing works by having a certain angle of attack relative to the airflow. The lower air pressure on the top surface of the wing effectively sucks the aircraft upwards. When you have an aggressive angle of attack, almost using the air below as a cushion, it is called a high alpha.
You'll see lots of jets doing this to slow down, especially upon landing. All you have to do is pull back while applying power to raise the nose of the plane.
With the Vapor, it's exactly the same as the jet. You'll find using the high alpha to manoeuvre around tight spaces indoors to be a valuable tool in your metaphorical pilot toolbox.
If you pick up a Vapor from the Flite Test Store, make sure you let us know how you find it by leaving a review! Another way to let others know of your experience is to write an article of your own here of flitetest.com. Have fun flying!
Helpful Links
Article by James Whomsley
Editor of FliteTest.com
get it: 70/10 ;)
