E-Flite Cessna 150 - MIDAIR CRASH
by FliteTest | August 4, 2017 | (0) Posted in Reviews
Josh and TJ check out the E-Flite Cessna 150...and then they crash.
What we liked
  • The PNP (plug-n-play has easy to connect wings
  • Can be assembled in less than five minutes—push and twist lock set
  • AX3S SAFE mode available to bind—but can turn off to get more aerobatic flights
  • Great for intermediate pilots, and a great first BIG plane
  • Beautiful shocks in the front—incredible landing gear
  • Tremendous scale detail
  • Versatile plane
Get your own E-Flite Cessna 150 here!
Specs
  • BNF (bind-n-fly): need your own transmitter and battery
  • Wingspan: 83.7 in (2125mm)Length: 61.8 in (1570mm)
  • Flying weight: 8.9-9.9 lbs (4-4.5kg)
  • Motor size: 50-size brushless outrunner (installed)
  • Radio: 5+ channels
  • CG: 95-105mm back from leading edge at wing root
  • Recommended battery: 4-6S 4000mAh LiPo battery
