Don't underestimate the value of FailSafe
by Curryit | March 4, 2019 | (3) Posted in Tips
I have been rather lax in setting up FailSafe on my aircraft until I was forced to at a recent FPV race competition. Realizing how easy it is I have subsequently set-up my other planes as well but never took it too seriously until I experienced radio Tx interference this past weekend on my first flight with a new GoPro on the plane.
Have a look at the video link below. You can see and hear how the FailSafe kicks in as the throttle cuts off and the plane dives towards the water. I had full opposite aileron but no response until the last second! Hence the vicious over correction to the left.
If it has not been for the FailSafe kicking in I believe the aircraft would have dived into the water with power on causing to me to lose plane,  GoPro and electronics.
I hope this near miss will prompt you to set your FailSafe on your aircraft if you don't do so already.
Cheers
Razgriz on May 9, 2019
it doesnt work if the rx voltage is too low, i learned the hard way flying my dlg......
nikolainekrut on October 11, 2019
What kind of OSD is that?, or are you using something else because it looks amazing.
