DangerDane FPV - Bobble Nose v3.5 at 500m altitude
by Christian Jeppesen | August 7, 2013 | (0) Posted in Just Fun
 There where a strong wind that day so i had to fly a lot in the same direction, other than that it was pretty smooth :-).
THE BOBBLE NOSE v3.5
This is a video I made with my scratch build plane called "THE BOBBLE NOSE" this plane was originaly my first scratch build plane. But after a dusin overhales its now a APM 2.5 FPV plane.
Specs.
Wingspan. 1.4m
Length. 1m
weigth. 1,4kg.
Foamboard 5mm for wing and tail.
15mm x 15mm balsawood tailboom
packeging cardboard 8.5cm x 8.5cm squaretube fugelarge.
Plane Parts.
Motor: 2 x NTM Prop Drive 28-26 1000KV / 315W (short shaft version) original from my tricoptor.
Prop: 9:6 SF
Motor Battery: Zippy 3S 5000mah 20C
ESC: 2 x Multistar 30A opto
Servo:Turnigy 9g.
FPV.
GoPro 3 Black.
5.8ghz 1000mw tx BOSCAM w. clowerleaf.
2 x RX. 805 5.8ghz w. skewplaner and 7 turn helical.
EASY DIVERSITY.
A/V USB for PC (blackbox).
FatShark BASE SD video headset.
Car jumpstarter 12V power for groundstation.
Control.
AMP 2.5 w. UBLOX GPS
FPV / APM / servor Battery: Zippy 3S 2500mah 3C
UBEC: 3A 5V
Futaba T8FGs. w. RX.
These pictures where taken while it had the dummy FPV equipment and old nose on + 9 x 6 instead of 10 x 4.7 like on the pic.
No Comments Yet
Be the first to leave one!
