Got any traditional balsa wood plans around? You might be able to build a foam board model from them. Here's how.
If you're wanting to design a model from scratch, you'll often have more chance of success if you start with an existing model. You can switch up one of our Flite Test designs super easily - but what if you want to go to the drawing board? If you've got some balsa plans in a draw somewhere, you can often use them to base a foam board model from. It's very simple to do, so let's show you.
You will need:
- A balsa model plan
- Foam board for the model itself
- Cardstock for the templates
- Paper for tracing the plans
- Pens and pencils
- A metal ruler
- All the normal tools you'd find in an FT Crafty Kit
- A bit of lateral thinking
Step 1: Identifying the plans
First, you're going to need to choose a good plan to work from. This is absolutely critical for the success of the project. Try and go for something a plan to build a relatively simple balsa wood model to start with. You don't want one with lots of rounded, complex shapes to reproduce - get one that's square with lots of straight lines.
Step 2: Creating Templates
For this, you'll start by transferring the standard shapes of the aircraft to paper before making more rigid templates with the cardstock. Before you start, here's a video from Josh showing you how to make solid templates.
- Grab some paper and lay it over the plan.
- Trace the main faces of the fuselage and wing. For the fuselage, create seperate top and side pieces.
- Now trace these paper templates onto some cardstock for rigidity.
- Draw lines on these pieces to show where seams, score cuts, and removed foam will go. This is where the lateral thinking comes in. Try working to our A and B fold technique style.
Step 3: Forming the model
Building a model from a plan that wasn't intended for foam board is a little different from assembling one of our speed build kits. It takes a little more fiddling around and 'making it up as you go'. As long as you have the basic shapes, you should be able to muddle through and assemble something that represents the original balsa plan airplane in foam board.
Hey presto! It's an airplane.
Step 4: Test Fly!
All that's left is to unleash the aircraft let her go! What's great about building from balsa plans is that they will recommend what power choice you should go for and show you where the CG would be. This should all be similar for the foam board version of the model which makes it extremely easy for you to set up and get flying. Have fun with your new absolutely unique RC airplane!
Extra tips
- Keep your templates - you can build another plane.
- Share you templates online so others can build your design.
Will you try this idea? Let us know in the comments.
More from Design Class:
Article by James Whomsley
Editor of FliteTest.com
Contact: james@flitetest.com
YouTube Channel: www.youtube.com/projectairaviation
Maybe A MkII in foamboard....
