I am terribly sorry it has taken me so long to provide build instructions for my Red Bull Air Race Inspired build. I found out that filming a build video was a lot more work than I first thought and that I just didn't have the proper camera angles to accurately show you how to build this plane. So I created a set of build instructions (the attached pdf at the bottom of this article) with lots of images to give you a good idea of how to build it. I also made significant changes to my original build plans because there were some significant flaws. I apologize if you attempted to build this using a previous version of my plans. In the body of this article I will outline the major changes I made to the build plans.
While trying to build the nose, I came across a big problem with my motor mount. It seems that I had it stopping about 1/2 inch away from the front edge of the nose and the side plates were too far apart to accommodate an FT firewall. I adjusted this and now the bottom plate of the motor mount is flush with the front edge of the nose and the side plates are the right distance apart. I also had to shorten them a little bit so the firewall could rest on top of the front edge of the bottom plate.
Motor mount placement marks (where paper is removed) too far from front of nose. | Correct motor mount placement marks. | With the correct placement of the motor mount, the firewall should be flush with the front of the nose. |
While getting ready to rebuild the nose, I decided to make another change to the way the nose piece comes together. In my first design, I had the top of the nose join with the corner plate. This made it difficult to glue the nose together without it appearing a little deformed. It also required a bevel on one of the edges to ensure they came together flush. So I decided to move this joint to the middle of the top plate. Now, one half of the top plate is on either side of the nose piece. With the nose going together this way, you don't need to bevel any edges and you can push the plate against the table while gluing the pieces together. If there is some deformity, at least it won't be lopsided.
First iteration where the nose piece joined at a corner. | Nose piece now joins at the middle of the top plate for an easier assembly. |
One of the things I was unhappy with in the original design was how I held the canopy on the body. I used large popsicles sticks that stuck out of the front of the canopy to catch on a dowel across the nose. I didn't like this because it required two more popsicles sticks inside the front of the canopy to add strength. I left the popsicle sticks that go through the back of the canopy and act as supports through which a barbecue skewer can go through. I saw no need to redesign this, although I do get frustrated with trying to pass the barbecue skewer through the two popsicle sticks. The new design has doubled over pieces cut out of foam board that catch on a foam board plate attached to the front of the fuselage section. These pieces glue to the sides of the canopy section and pass through holes in the front of it. The plate in the fuselage slides through slots cut out of the fuselage and has four small foam board wedges that provide vertical support to the area where the canopy pieces apply pressure.
First design with popsicle sticks protruding from front of canopy. | A long dowel was installed to catch the popsicle sticks. |
A long thin plate, instead of a dowel, that glues to the front of the fuselage section acts as a catch. |
The last thing I added were pieces that help you fold the wings. They keep the bottom of the leading edge at the proper angle when folding the wings. In the first design, I didn't use any kind of guide to hold the wings or provide a reference while folding them. Being that this has a symmetric airfoil, it is too easy to fold the wings and end up with a non-symmetric airfoil. Also, the wing root decreases in thickness. Because of this, you cannot just lay the wing pieces on a flat surface when joining them. Luckily, I discovered that the difference in thickness from the wing root to the tip is barely bigger than the thickness of a piece of foam board.
Build Instructions
Updated build plans
