Cessna Skymaster
by rcspaceflight | August 15, 2014 | (10) Posted in Projects
Intro:
This scratch build is based off of the Cessna O-2 Skymaster. I kept it as scale as possible, but I also made some changes and liberties. Mainly I made the control surfaces bigger.
This plane is designed to be a twin engine, two power pods making it a swappable, but I have only tested it as a pusher. I think the pusher set up will be the most popular and will make this plane a great FPV plane. Without the front power pod, there is plenty of room for FPV gear and a battery.
This plane is designed around an 8 inch propellor. There is no room for anything bigger. However, the height of the fuselage makes it completely safe (maybe not "completely") to hand launch and you can belly land the plane without any worry about breaking the rear propellor.
Video:
This video ended up longer than I would have liked, but I got a lot of great footage that I wanted to share. I thought about adding music, but that's debatable. The audio doesn't always line up and I probably should have tried to fix it, but it's close enough. I was nice and lowered the volume for the on board footage.
(All flying was done Line Of Sight.)
Specs:
- 41.75" wingspan
- 30" length
- Made with less than 3 sheets of foam board, 4 bamboo skewer, etc.
- 1300kv Hobby King motor
- 8x4 GWS style prop
- 25amp Hobby King ESC
- 2200mah 3S battery
Plan Preview:
Sketchup File with Printable Plans: Skymaster
PDF Version of Printable Plans: Skymaster.pdf
***(note: Printable Plans are different than the Preview. I condensed the Printable versions.)
Build Tips:
The majority of the plans are self explainitory. However, there are two things that I think I have to point out. One is because I do not have the standard colored lines on the plans. The other is an unusual building technique.
Tip 1:  Just like the FT Spitfire, the wings have a spacer. Unlike the FT Spitfire, the spacer is attached to the wings and is folded over. On the plans, it should be a dashed red line because the score cut is on the opposite side of the score cuts that create the airfoil.
Tip 2: The booms are three sheets of foam board thick and are hot glued together. However, there are also bamboo skewers inserted into score cuts to make the booms even stronger, in a very inexpensive way. The skewers should extend out onto the vertical stabilizers to brace them. The booms should also have some packing tape wrapped around them, but not completely. This works so well that I can actually carry the plane around by a boom without it feeling weak, as long as the battery isn't mounted. With the weight of the battery it does feel like I'm pushing it's limits.
Conclusion:
This plane flies more "scale" than "trainer" or "fun flyer". I probably should have made the wing tips undercambered, but you can easily alter the plans so they are. It does have some bad stall characteristics, but nothing out of the ordinary. Undercambered wingtips should fix most of the stalling.
I don't fly FPV, but this should be a great plane for it.
This isn't a good first plane, but should be a great first 4 channel with the pusher set up. If you keep the speed up it flies great. The prop is protected and the plane can withstand some abuse. And it looks great.
btallis on August 15, 2014
This has always been my favorite airplane, after seeing it star in the movie Bat-21. I have wanted to make a scratch build of this airplane, but have never got around to it. I also would love to see a full build video/writeup.
rcspaceflight on August 16, 2014
I have a lot more pictures and details of the build on the thread.
http://forum.flitetest.com/showthread.php?8981-DTFB-Skymaster-%28build%29
It just felt redundant to me to have all of the build pictures at both locations. I wanted to keep the article cleaner and more at a bare minimum. (But I admit to not taking as many photos of the build as I should.)
The thread has build pictures for Version 1 and Version 2. Both are built very similarly. Version 1 was bigger and had more pieces.
Tactical Ex on August 15, 2014
Been following the forum thread on this, good to see it in an article. Looks like a really fun plane. If I hadn't converted my simple soarer into a twin boomer I'd probably be building your skymaster.
PeterGregory on August 19, 2014
Really cool, I just found Zeke's parkscaleflyers.com C337, but much more complex a build. I'll be given your plan a try - nice job and good going with one of my favorite planes.
LordVader on August 15, 2014
Really nice build, flies good on one motor, probably screams on two.
Blaira on August 24, 2014
Hi I am new at this sort of thing but I am really amazed at what you do I am attempting to build this plane and hopefully will fly it soon
mediccby on August 25, 2014
This build is fun. I added some dihedral to the wing. Hopefully I'll have it finished up later this week.
CJGFX on August 15, 2014
Nice build. Can you post some photos of the finished plane, it's hard to see the finished result on the film.
Sorry. Bad habit. I seem to finish planes and then take them out to fly instead of taking a quick photo first. I just took three and added them to the article.
Yogenh on October 18, 2014
It looks good. It doesn't seem too hard to build
I think that it would really be great with a motor in the nose. Have you thought of doing that?
FeWolf on December 2, 2014
Thank You, love this plane
Cessna Skymaster
