cardboard Challenger space shuttle= build
by Adam Buildtip | May 26, 2013 | (5) Posted in Projects
this is the build of the space shuttle
sorry for bad English (I am from Slovakia)
cut the edges
measure horisontal 34cm and vertical 2 cm and draw it
measure vertical 4 cm from the line before and draw horizontal 32cm , than line the edges with the previous line
than measure vertical 21 cm form the hollow  and horizontal 15 cm
than measure vertical 4cm from the line that you drew before and horizontal 14 cm and than line the edgeswith the previous line
than cut it out
sand it with a sandpaper 180
tape the edges
take a big cardboard
 lay the wing on the cardboard
retrace
match the hollow at the wing with the cardboard
retrace
cut the second wing
match it
cut the rest of the wing/ on the edge of the wing 3cm and on the other side 7cm
tape it
when you have it take a fan and heat  the tape
bent the edges
take hot glue and glue two parts of the wing
when you have it take a cardboard and draw a triangel vertical 32 cm and horizontal 14 cm
cut it out
make two parts
tape the edges and glue two parst together
 glu them on the wing
now fuselage
take a cardboard
make with knife hollows and bend it
 make three stripes and glue them with the fue.
place it on the space shuttle
make vertical stabilizer
cut a line  and slide in the vertical stabilizer
 make the front of space shuttle
thanks for taking time to watch my build of space shuttle
if you want to build this plane i recommend using foamboard :)
Adam Buildtip on June 4, 2013
yes I am waiting for the elektronics
TheRCNewbie on June 4, 2013
That is so cool, man!
NoUsername on June 4, 2013
Outstanding job and very good photos.
Rc Mania Cyprus on June 4, 2013
Are you living in Greece or Cyprus?On one of the pictures there is a label with greek on it.BTW i am from Cyprus.
planemad man on June 4, 2013
jauka būvēt
EndoftheRoadRC on June 21, 2013
Haha thats awesome, look forward to the maiden,..good luck
Zpack on June 4, 2013
Nice work man! any plans to make it fly?
Arend on June 4, 2013
Nice, I would love to see it fly!
zvada on June 5, 2013
Impressive my friend! you should consider trying your next design with some Adam's Foam board! If you can make a space shuttle out of cardboard, who knows what you would do with the foam board! keep up the good work
nice build
c.sitas on June 4, 2013
Great job my friend. You should be thinking about making your living designing such things . you have the talent
thanks!!!!
