That's it I'm launching (after the 2 meters) in the construction of a 3.4 meter span, depron wing 6 mm ribbed into 3 pieces, one of 1 m central and both ends in 1.2 m. On the central two motors and on each end a motor, I left on the turnigy D3542 / 6 1000KV of 665 W in 3S with propellers of 11.25 X 7 APC. the all inclusive weight should be 4.5 Kg
a glimpse of the beginning of the wings with wing key consisting of a 2.5 m diameter 16 mm aluminum tube that fits into 3 tubes of 20 mm diameter of 1 m
here is the picture of the build
first printing the drawing and glue all the parts before cutting pieces
view how to mount the wing
cut all parts in depron
the start of the fuse
the empennage and its fixation
obligation to dismount it to get the plane into the car
eight nylon screws with spike nut
the assembly / gluing of the wing and nacelles with motor assemblies, the ESC are put in the nacelles to shorten the length of wire with the engines
put in cross to verify the good symmetry of the whole
final assembly and test engines
try loading the set into the car
and at the end the two test fly and field editing
the third test fly with sound system
and with FPV set and OSD tarot TL300L and multicam
new test
thank you
Diego
merci beaucoup
regards from Nancy France
