Bebop with Skycontroller Review
by RCSchim | February 10, 2015 | (7) Posted in Reviews
I was patiently waiting for this little tech stuffed drone to come out. I bought the AR.Drone 1 back than and loved the new concept. Skipped AR Drone 2 because I didn't see much difference (and had enough other quads) but this one was on my wishlist!
It's a wifi controlled flying cam rather than a drone.
It looks like a camcorder with arms and props ;-)
Video quality:
At the time of this filming I didn't have a day with good sunlight (were the cam performs best) - so you see rather poor performance but a decent stabilisation (it was cold and gusty this day, didn't wanna leave my car). This session was fun - maybe I'll post the whole video from my first flights.
As soon as we have some nice weather I will show you that the cam here can work really nice.
___________________________________
minor Problems I found:
Apps: make sure you always use the most current (my iPad app was 1 week old and had an issue with GPS status which I didn't have on my android).
Map-Mode:
You should be able to see your drone on a google maps style view but you have to preload this data. Because if I'm connected to drone I have no internet (even if I turn mobile data on my android stays just wifi and has no internet).
HDMI / Video:
I wanted to try my Fatshark Dominator HD, got a HDMI to MICRO HDMI cable and connected it to the skycontroller. Only got a few seconds of image on the goggles - flicker than black.
If I connect HDMI monitor to the skycontroller it works - so it must be on Fatshark side - or it's an incompatibility...
Hope I find I way for this.
But anyhow - the iPad view works really well. It's sharp image - but with some lag and occasionally stuttering video (control data is prioritized over video).
Tech spces:
- weight: 393gr (without bumpers)
- flying time (11mins? I estimate 8-10mins with std. 1200mah 3cell battery)
- fully stabilized 1080pcam (records fisheye 14mp and computes software stabilized video)
- tilt-able video (with two fingers on phone for example)
- video and control over 2.4 or 5ghz wifi
- can be controlled with only phone or dedicated skycontroller
- range varies (with wifi noise, used controller, channel,...) from only 100m to 2km (with skycontroller) under optimal conditions
- ios and android app (with lots of cool features)
2 different sets:
Bebop alone (500€)
Drone
2 batteries
wall plug charger
4 spare props + propmount tool
bumpers (for indoor)
Bebop + Skycontroller (900€)
all of above +
1 more battery (used for skycontroller)
skycontroller ("real joysticks", strong wifi repeater, directional antenna, Smartphone/Tablet mounting)
sunshade (2 Parts)
7" Tablet adapter
thomasbaxter5 on February 10, 2015
Thank you for the detailed presentation Schim. The only thing I am not clear on is the video transmission quality. Is it similar to say a Fatshark video resolution? On your video the resolution looks very good - maybe HD quality. Also, does the video resolution change between 5.8 and 2.4gHz? The reason I ask is whether this could be an alternative to DJI Lightbridge.
RCSchim on February 10, 2015
Hi, The video link is good quality. In good range is almost hd. If you get bad signal it gets blurry rather than having the static we know from analog video. 2.4 or 5.8 ghz does not change quality as it would in analog. I had no chance to test lightBridge but i think it's another liga... i will try to show Video quality ina flight session
