Battery charge marker
by capitaineflam25 | December 4, 2013 | (10) Posted in Tips
I have a lot of batteries, some on my workbench, some in my field bag, and sometime i forget which one is ready to fly and which one needs a charge.
I now apply a small piece of shrink tube on the plug, and it gave me a cheap "cap charge marker".
If needed you can fold a piece of paper/plastic on the tube to get a warning message you need before flying with the battery.
When i found a battery without this reminder cap, i know that it has been plugged and that i need to check its charge.
capitaineflam25 on December 12, 2013
For my XT60 plugs i used 14mm diameter Heat Shrink Tube.
Just after you shrinked it, it can stuck a litlle bit on your plug, just unstick it with a toothpick or something similar.
Red20RC on December 14, 2013
I really like these - so much so I went out into the workshop and made 10 of the things myself. I put green tags in mine that say "Charged" that way I no which ones to take out of the box when I head for the flying field.
randall_l on December 18, 2013
That's an interesting idea, thanks for sharing. I put my used batteries velcro (belly) up to tell me which ones need charging--zero material cost. Currently managing over 40 LiPos with no issues so far.
Cheers!
Randall
Krako on December 12, 2013
The simplest ideas are the best! thanks for the tip.
iPeel on December 12, 2013
I simply wrap an elastic band around every battery I take off charge, then remove the elastic band when I use the battery.
rslegge on December 12, 2013
Ditto, works perfectly
ccrawford on December 12, 2013
What diameter shrink tube works best?
