Antenna tuning using the RSSI method.
For more information on the type of antenna I have built have a look at IBCrazy's article:
http://www.rcgroups.com/forums/showthread.php?t=1159968
Cheers.
Cheers.
The theory is the same so I stuck with the common name.
If you can get your hands on The ARRL Antenna Handbook, that'll help you a lot. Look for LEO (Low-Earth Orbiting) satellite antennas for the 70cm Ham band as I think those are the ones that'll be most useful for your needs. 433MHz is, by the way, within the 70cm Ham band.
