Scratch build, Baby Blender 2, depron version, (only the tail was made with foamboard).
This version is a bit bigger than the original and it looses the "cartoon shape" but flies a bit better.
Enjoy the maiden flight video ->
Paint work is on going!
Wingspan: 800 mm
Fuse: +100mm to the tail, and +35 mm to the nose to keep the CG
Horizontal stab: +10mm to the trailing edge (not to the control surface!), 20-20mm to each side
Vertical stab: +5mm to Leading edge
Since you've scaled it up, may I ask what electronic setup do you use on it?
Thanks in advance.
