Hi Flitetester's !
As many of us, I've been entering FPV with low budget. I've been seeking all around the WWW for months before I found the solution that suited my requirements :
All in one solution (no cables messing around while flying)
,integrated battery,integrated 5.8Ghz receiver (Fatshark Compatible 5740 to 5860 frequencies), integrated DVR with micro SD slot, at least 5'
At the beginning of my searches, I wanted to buld my one setup, as this guy did (RCTUTOR), but the haier screen isn't available anymore, and the DIY soldering skills were a little over my acceptance level...
See more details on Youtube HERE
Later, I saw many tutorials of how to build DIY FPV googgles (search for DIY FPV GOGGLES on Youtube), quickly followed by RC suppliers
FLYING WINGS ; foam goggles with fresnel lens, but without the screen (Search on Ebay for REVERSE LCD to find ~20$ screen)
HOBBYKING ; foam goggles with all inclued (screen + fresnel lens)
I was wondering if I could maybe buy a 7' single reverse monitor sold on ebay for ~30$, but the idea of all the wires messing around (power, 5.8 VRX) stopped the project.
Then, I saw Daniel's (RCTESTFLIGHT) review for a all-in-one 5.8Ghz fpv screen, but without fatshark frequencies compatibility..... what a shame....
Finally, I found out the same product, but with fatshark frequencies compatibility !
That's what I finally decided to purchase directly from the supplier for 96$+25$ shipping to france + 5$ paypal fee : 126$ total (93€) !
.jpg)
Specifications :
Items
Value
Wireless Receiving
Wireless freq.
2.4GHz–8 channels
CH1: 2414MHz; CH2: 2432MHz; CH3: 2450MHz; CH4: 2468MHz.
CH5: 2490MHz; CH6: 2510MHz; CH7: 2390MHz; CH8: 2370MHz
Within 5.8G-A 8 channels
CH1: 5865MHz; CH2: 5845MHz; CH3: 5825MHz; CH4: 5805MHz.
CH5: 5785MHz; CH6: 5765MHz; CH7: 5745MHz; CH8: 5725MHz
Beyond 5.8G-B 8 channels
CH1: 5705MHz; CH2: 5685MHz; CH3: 5665MHz; CH4: 5645MHz.
CH5: 5885MHz; CH6: 5905MHz; CH7: 5925MHz; CH8: 5945MHz
Within 5.8G-C 8 channels
CH1: 5733MHz; CH2: 5752MHz; CH3: 5771MHz; CH4: 5790MHz.
CH5: 5809MHz; CH6: 5828MHz; CH7: 5847MHz; CH8: 5866MHz
Within 5.8G-D 7channels for FPV
CH1: 5740MHz; CH2: 5760MHz; CH3: 5780MHz; CH4: 5800MHz.
CH5: 5820MHz; CH6: 5840MHz; CH7: 5860MHz; CH8: SPI
Beyond 5.8G-E 7 channels for FPV
CH5: 5885MHz; CH6: 5905MHz; CH7: 5925MHz; CH8: SPI
Sensitivity
-88dB
Receiving distance
100 meters
AV IN
TV system
NTSC / PAL
Output voltage
3.6-4.2 V
HD 5-inch LCD screen
Active area
108mm(W) X 64.8mm(H)
Resolution
800 X 480 Pixel
Luminance for LCM
200 cd/㎡
Cape clear 5-inch LCD screen
Active area
118mm(W) X 62.8mm(H)
Resolution
480 X 272 Pixel
Luminance for LCM)
300cd/㎡
Video
Resolution
720*576 / 640*480
Video compress
MPEG-AVI 30fps
Play format
MPEG-AVI
Audio
Frequency
20HZ-20KHz stereo
Earphone Output
Left: 20MW+ right 20mW [16O](suit to largest volume)
Speaker
1W
Format
JPG/JPEG
Storage
External SD card
TF card 1GB-32GB(optional)
32GB recording time
10-32 hours
1GB photos
15625pcs
Operating system
PC
Windows & Mac OS
Port
USB 2.0
Language
Multiple
Power
Voltage
DC 5V
Current(receiving mode)
660MA
Current( recording mode)
680MA
Current(recording with off-screen mode)
340MA
AC adapter
DC 5V 2A
Built-in battery
Li-battery 3200Mah
Standby time
Wireless record
≥9.5 hours(off-screen); ≥5hours(on-screen)
Wired record
≥12 hours(off-screen); ≥6hours(on-screen) *LED camera not included.
Size (L x W x H)
131mm x 86mm x 18mm
Weight(g)
205g
Don't forget, you've got to ask for TE968H-D (D-Channel is compatible with Fatshark-Immersion RC VTX) !!
More info and projects on
Enjoy :-)
http://www.rcgroups.com/forums/showpost.php?p=29175518&postcount=800
