SOOOO, i have just finished building my FT racer.
I am a complete noob at rc planes, had never flown one before this morning.
The build process of the plane was even easier than i could have hoped it to be. follwing the video was a breeze and the final product turned out great.
So how did i go at flying it?
After quite a while on a simulator i rounded up the courage to take it out the back and give it a go, The first launch didnt go so well and saw me touch down about 2 meters infront of myself after a toss that was much too shallow.
The second attempt was much more sucessfull. A steeper launch angle and she was off. After that it was an apsolute piece of cake. No trimming was needed for my plane, it flys perfectly straight hands off on zero trims wich makes flying it stress free.
i have 30% expo dialed in and it is very forgiving and an allroud friendly plane to fly.
so at the time of writing this i have put 6 batteries through the plane without incident after having only ever flown a simulator before this morning,
Just goes to show how valuble a good simulator is to any new pilots efforts.
i could not be happier with the way the plane has turned out. It looks good and flys great. And best of all i am now into the hobby and have conqured my first flight,
Thanks flite test for an awesome machine.
Specs: Motor: turnigy 2826-1400kv
ESC: turnigy 40 amp plush
RX: spectrum ar6210 (came with my transmitter so i used it)
batteries Turngy 2200mah 3s.
flight time currently- 8 minutes (1200mah used according to charger.)
EDIT: added photos of battery compartment.
i will put all settings for my DX6i below HOWEVER i strongly recomend seeking advice from someone other than myself. I have a grand total of 9 flights experience and my setup is almost certainly not optimal.
with that said my settings are as follows.
D/R&EXPO
- aile-0- 100% + 20%
- elev-0- 90% + 30%
-rudd-0- 100% + 30%
- aile-1- 100% + 10%
- elev-1- 100% + 10%
-rudd-1- 100% + 10%
NOTE: i have not tried high rates yet,
TRAVEL ADJ- all 100%
SUB TRIM- all zero
FlAPS-
NORM- FLAP-0 ELEV-0
LAND- FLAP-30 ELEV-10
NOTE: i am using a AR6210 rx with Aileron servos pluged into the Aileron plug and aux 1 plug to allow flapperons.
MIX1-MIX2- both not used,
DIFFERENTIAL- not used.
SETUP LIST.
MODEL TYPE- ACRO
MODEL NAME- RACER
REVERSE- Rudder reversed.
THRO CUT- INH
WING TAIL MIX- DUALAILE - ACT
- V-TAIL -INH
-ELEVON -INH
D/R COMBI- INH
TIMER- DOWN TIMER- 8:00
SWITCH-TRAINER
RANGE CHECK- INH
POWER SETTING - A-EU 328
note: No idea what above means. lol thats just how it was,
MODULATION TYPE-AUTO
Hope this helps but again i advise u check with an experienced pilot.
I would hate to see you crash your plane because i told you to do it wrong.
Good luck
Cheers
Scottie
Thanks again, Frank
haha when i was building my wing i glued the spar to the wrong side. then had remove it and glue it back on the other side. and it still turned out great. so i wouldnt worrie too much about rustyness haha
Im using a 7x5 prop on this motor.
what do you use?
Cheers
Scottie
i usually dont use full throttle either as my flying field is a bit on the small side so 3/4 throttle seems to be good speed.
Thanks for the information on the batteries, thats very helpfull. :)
