Description
Short flight to test the new motors (DT750) and the shorter frame (40cm arm length instead 50cm). I got wind on this day, that's why sometimes you'll see the video shaking a bit.
Local info:
Country: Brazil
City: Florianópolis
Beach: Praia Mole
GWS EP Propeller (RD-1047 254x119mm) (6pcs/s
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10055&aff=557863
DT750 Brushless Outrunner 750kv Motors (new!)
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=6247&aff=557863
Turnigy 2200mAh 3S 25C Lipo Pack
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8934&aff=557863
TURNIGY Plush 18amp Speed Controller
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=4312&aff=557863
HobbyKing Quadcopter Control Board
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=17537&aff=557863
BMS-385DMAX Digital Servo (Metal Gear) 4.2kg
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8761&aff=557863
Prop Saver w/ Band 3mm (10pcs)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8240&aff=557863
Nylon XT60 Connectors Male/Female (5 pairs)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9572&aff=557863
40CM Servo Lead (Futaba) 32AWG Ultra Light (
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9704&aff=557863
10CM Male to Male Servo Lead (JR) 26AWG
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=21758&aff=557863
Front Wheel Steering Arm & Mount Set 40mm (5
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8432&aff=557863
ImmersionRC 5.8Ghz Audio/Video Transmitter -
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=17507&aff=557863
Antenna FPV 5.8GHz Circular Polarized spiroNet
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=27750&aff=557863
Fat Shark Predator FPV Headset System
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=20671&aff=557863
Fatshark FPV 5 Pin Molex to A/V Plugs Connec
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=20653&aff=557863
Turnigy 9X 9Ch Transmitter w/ Module & 8ch R
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8992&aff=557863
GoPro Hero 2
http://gopro.com/wp-content/uploads/2011/10/4_683x426Surf031.jpg
IMAX B6-AC Charger/Discharger 1-6 Cells
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6478&aff=557863
How to built it:
http://rcexplorer.se/projects/tricopterv25/tricopterv25.html
No Comments Yet
Be the first to leave one!
