I heard about this trick a while back and have found it very useful. If you want a strong joint between two objects, thread and superglue can be a great way of doing it.
For example, the other day I wanted a way to mount my small video camera to my RC plane. My camera didn’t come with a tripod mount, so I added my own. I used thread and superglue to give an extremely strong joint between a 1/4-20 nut and my camera. Now I can hang the camera from my plane and I don’t have to worry about the glue joint coming apart mid-air.
To do this properly, it is best to rough up the two surfaces you are gluing. Then wind/wrap thread around the joint of the two surfaces – I use roughly 36 inch lengths of thread and then soak in superglue. I like to do it in layers because it makes it easier for me. So, I wind the 36″ piece, soak in superglue, wind another 36″ piece, soak in superglue, etc. I do this till I feel there is a sufficient amount of thread and super glue. The windings of thread and superglue creates a super strong, plastic-y, fiberglass-like material.
I honestly cannot figure out how to post images to this article, so if you want to see some example projects go HERE
If you would like to see some of my other projects and tips check out my blog - http://www.backroomworkdesk.com/
Thanks for the tip.
