If you fly RC models, you should use loctite or thread locker.
Why you ask ?
As it will keep you model from lossing screws midfligt, on a helicopter there are many more small vibrations then on a plane, so on a helicopter it is a NO GO, not to use it.
When I put a new helicopter together, i will first assemble it without the use of any thread locker, and then when I happy with it, I will unscrew every screw put thread locker on it, and put it back in.
Takes a little longer, but time well spend if you avoid juse one crash.
the product use here is: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10959
cheap (about 1 $), used it a lot, and no issus so far.
No Comments Yet
Be the first to leave one!
